MUFF WIGGLER Forum Index MUFF WIGGLER
Harder, Better, Faster, Stronger
Listen to Wiggler Radio - Click Here
MUFF WIGGLER Advanced Search
Update: 8 16bit cv outputs from computer!
Goto page 1, 2, 3, 4, 5, 6  Next [all]
Post new topic   Reply to topic    MUFF WIGGLER Forum Index -> Modular Synth General Discussion
Author Update: 8 16bit cv outputs from computer!
wetterberg
Last Visit: 26 Nov 2014
PostPosted: Sat Oct 25, 2008 6:30 am    Post subject: Update: 8 16bit cv outputs from computer! Reply with quote Add User to Ignore List
Alright, so this has been the holy grail for me in terms of modular synth+computer integration, and I had all but given up:
my fa-101 has DC blocking capacitors (and I'm not overly keen on hacking it wink ) and my 828mk1 had been bricked by horrible drivers...
I had even started looking into weird OSC->CV solutions, and had cash in hand, ready to buy the Kenton Pro 2000, which is expensive, and still only runs at midi resolution.
Well, now things have changed! I magically got the 828mk1 to WORK and I speedily set up a test rig to see what I could get out of the unit.
IT WORKS! Oh my GAWD this is so cool! I have a 4-way step sequencer, a fully synced ADSR and an LFO modulating an LFO, coming out of 5 different outputs, and as far as I can tell the voltage is REALLY high - good enough to do proper pitch scaling and so on - this RULES! It also happily generates trigger outputs, although I am going to build a trigger interface instead.
So - what does it sound like?
http://wetterberg.dk/uploads/828_modulator.mp3
(sorry for the crummy recording, weird interference on my recorder... wasn't there when monitoring directly, grumble)
What's going on?
the patch is 110 VCO->116 waveform processor->106-1 Xtreme filter
Computer is step sequencing PWM, clipping and symmetry CV and filter cutoff. Not too fancy, just enough for me to play around. Manually adjusting resonance and levels. adsr is going to the filter (yes, that's right, I'm not using an adsr in my modular!) and the lfo-modulated-lfo is controlling the filter as well. both lfos are sinewaves, and going into audio range is so damned easy.
The sequencer patch was just thrown together quickly - every 8 bars all 4 8-step sequencers are randomly set. But the results are surprisingly funky, if you ask me. I'm looking forward to attempting something sequenced on my Lemur! eek!
What does it look like?
View user's profile Send private message AIM Address MSN Messenger
Soy Sos
Dub Surgeon
Last Visit: 28 Jan 2015
PostPosted: Sat Oct 25, 2008 9:33 am    Post subject: Reply with quote Add User to Ignore List
Hell yes!! Great work! I have Max/MSP and got very put off the path and kind of gave up. This should be good reason to give it another push. AND I have the same 828 you have. I guess you get 3 of these:
SlayerBadger! SlayerBadger! SlayerBadger!
Modulation Maniac
Last Visit: 27 Jan 2015
PostPosted: Sat Oct 25, 2008 12:32 pm    Post subject: Reply with quote Add User to Ignore List
Damn that is really really cool 8)
dkcg
PostPosted: Sat Oct 25, 2008 12:53 pm    Post subject: Reply with quote Add User to Ignore List
Awesome!!! SlayerBadger! w00t
I see you're running Max5. smile
I like the round corners now.
I've been thinking about some sort of master clock/control hub, and I keep thinking Max would be the easiest most controllable, repeatable way. Congrats dude, I gotta get back to using Max with the modular too.
Nice to know the 828mk1 can send low frequency outputs too! 8)
Suburban Bather
Miami Flesh
Last Visit: 07 Jan 2015
PostPosted: Sat Oct 25, 2008 2:43 pm    Post subject: Reply with quote Add User to Ignore List
Dammit Andreas! stop making me gas over software I don't want to buy wink
amnesia
PostPosted: Sat Oct 25, 2008 3:59 pm    Post subject: Reply with quote Add User to Ignore List
is this doable with other sound cards? i have a presonus firepod can you send us the max file please
vicmod records
vicmod blog
modular vids
tumblr its in my brain now
discog
cray news
flts
Last Visit: 25 Jan 2015
PostPosted: Sat Oct 25, 2008 4:15 pm    Post subject: Reply with quote Add User to Ignore List
Any sound cards that don't have DC blocking capacitors in their output stages should do at least passably. Lots of audio interfaces have those though, but you can try out yourself.
Scaff
Elbe Kontrollspannungsverein
PostPosted: Sat Oct 25, 2008 4:19 pm    Post subject: Reply with quote Add User to Ignore List
yeah, please post a link to the file. Great Job! we're not worthy
wetterberg
PostPosted: Sat Oct 25, 2008 4:42 pm    Post subject: Reply with quote Add User to Ignore List
I say that if you have an aging audio interface and this *doesn't* work, and some soldering skills then open her up and short out the caps twisted
One thing that was unforeseen is that the DC on the outputs - and the flow of electricity back and forth between the modular and the 828 - made *recording* simultaneously on the 828 quite impossible, unfortunately. Otherwise I'd be half way done with a cv recorder already very frustrating - still, can't beat it for unlimited sequencers, envelopes, lfos and other malarky.
http://wetterberg.dk/uploads/analog_test.maxpat
- here's the patch, in all it's modesty - a lot of fun, nonetheless - loading it up will definitely let you know if your interface is dc-coupled or not.
SUBURBAN BATHER!!! wtf are you doing here - are you stalking me, mr. Zombie Man? Guinness ftw!
Suburban Bather
Miami Flesh
PostPosted: Sat Oct 25, 2008 5:37 pm    Post subject: Reply with quote Add User to Ignore List
lol
During a recent and rare occasion of checking out the Ableton forum, I saw a link to this site. I have a 22space .com system and almost all of the Moogerfoogers(just need both murfs and the mp-201). I'm also thinking about starting a Euro Rack system and I want your B R A I N ZZZZZZ. So, here I am!
dkcg
PostPosted: Sat Oct 25, 2008 6:22 pm    Post subject: Reply with quote Add User to Ignore List
I've seen used 828Mk1's as cheap as $150. smile
criticalmonkey
Last Visit: 26 Jan 2015
PostPosted: Sat Oct 25, 2008 6:49 pm    Post subject: Reply with quote Add User to Ignore List
i've been doing this with the motu 896 - I have no recording issues with it simultaneously - maybe because of the balanced connectors?
recently performed with it - really nice to have the sync control between gates, lfo's, etc
really pushing me in new directions -
wetterberg
PostPosted: Sat Oct 25, 2008 6:56 pm    Post subject: Reply with quote Add User to Ignore List
Good call! I'll have a go at going in balanced instead. erhm... but I don't have a di-box... Or do you just mean using a balanced connector at all?
futuresoundsystems
<3 CMOS
Last Visit: 28 Dec 2014
PostPosted: Sun Oct 26, 2008 9:08 am    Post subject: Reply with quote Add User to Ignore List
I'm severely tempted to hack my old Edirol interface now...
Unique designs and ideas in sound since 2005:
http://www.futuresoundsystems.co.uk
View user's profile Send private message Send e-mail MSN Messenger
wetterberg
PostPosted: Sun Oct 26, 2008 4:14 pm    Post subject: Reply with quote Add User to Ignore List
you know, I am too, even though I found the 828 to work... it's just bridging a few caps... hmm.
wetterberg
PostPosted: Tue Oct 28, 2008 6:29 pm    Post subject: Reply with quote Add User to Ignore List
Another update:
I've finished installing my new modules today, and thought I'd see if I can scope out the tracking from my 828 into the famed doepfer a-110 vco.
well... suffice to say I get at least 5 octaves of PERFECT pitch, at least as well as I can measure it in a hurry.
I now have an 11*6 keyboard matrix laid out on the Lemur, maxMSP applying portamento, etc. I really hope I get a chance to record some video of this process tonight, it's turning out to be a LOT of fun.
cebec
Last Visit: 04 Jan 2015
PostPosted: Tue Oct 28, 2008 8:01 pm    Post subject: Reply with quote Add User to Ignore List
So, is it safe to say the 828 mk I works better for this than the mk II and no modification is required?
Bandcamp | SoundCloud
wetterberg
PostPosted: Tue Oct 28, 2008 8:36 pm    Post subject: Reply with quote Add User to Ignore List
yes, from what I've learned:
Descriptions of the mkII as "hacky" etc do NOT fit the mkI - it's like plug and play.
wonderful tracking, it generates trigger pulses at very high audio rates too...
I have band rehearsal in roughly 30 hours, going to try to sync it up with Live and so on.
dkcg
PostPosted: Tue Oct 28, 2008 10:32 pm    Post subject: Reply with quote Add User to Ignore List
I may have to pick up a MK1 to check the difference. The Mk2 seemed kinda aliased on the scope, the LFO ramps were a little steppy, seemed to work better at higher resolutions, 96k was about twice as smooth as 48k, 44 was almost the same as 48. What sample rates are you using with the Mk1?
Howl at the Moon
PostPosted: Tue Oct 28, 2008 11:46 pm    Post subject: Reply with quote Add User to Ignore List
uuuhhhmmm . . . I don't get it! seriously, i just don't get it What da heck is going on here!!!!!???? question
Post new topic   Reply to topic    MUFF WIGGLER Forum Index -> Modular Synth General Discussion All times are GMT - 5 Hours
Page 1 of 6
