5U MOTM Rack w/ Dual Sides
Author 5U MOTM Rack w/ Dual Sides
Entrainer
Anyone know of a dual sided MOTM rack enclosure?
I want to throw a MOTM 900 Dual Power Supply in the back.
I'd need it to be "exactly" 5U, as space in my rack is limited.
Otherwise I could go with a rear mounted power supply, but
the star distribution + other features of the 900 are appealing.
The depth would have to be enough for the 900 on the back,
and some modules in the front.
I could put blanks, maybe with ventilation, in the remaining
7 back spaces.
Contents would be ZO + Hordijk.
Thanks-
sandyb
sorry if this is really obvious.
i'm guessing your rack doesn't have the vertical rack rails at the back as well as the front? or some way you could fix some on there?
if it did then it would be easy just to use the normal MOTM rack rails to mount your power supply on.
Entrainer
LOL. So obvious that I completely overlooked it.
Thanks-
sandyb
w00t
haricots
hahaha. that's what I ended up doing and was going to suggest the same.
