Who makes analog percussion modules like this?
Goominim
Post by Goominim » Sat May 19, 2018 1:23 pm
This is from a PAiA the Drum kit. I'm looking for something similar that's prebuilt.
Dcramer
Post by Dcramer » Sat May 19, 2018 1:57 pm
I’m sure I’ve seen a couple of designs that are similar in the DIY world that may be available prebuilt.
Maybe check the Elby page and EMW as well as checking in the DIY forum. :tu:
Goominim
Post by Goominim » Sat May 19, 2018 2:32 pm
Dcramer wrote:I’m sure I’ve seen a couple of designs that are similar in the DIY world that may be available prebuilt.
Thanks, just sent them an e-mail. Also, wondering why my YouTube video didn't post correctly.
moremagic
Post by moremagic » Sat May 19, 2018 3:16 pm
remove the s in https for the youtube link to lost right :miley:
adam
Post by adam » Sun May 20, 2018 5:43 am
you could check out the pittsburgh synth box and block modules, i think they have all that, the later one has a low pass gate
R.U.Nuts
Post by R.U.Nuts » Sun May 20, 2018 6:50 am
Preset sounds but cheap and six voice polyphony:
http://ladik.ladik.eu/?page_id=71
...or you could try and roll your own. The sounds in the video sound pretty much like filter pings to me. So maybe try plugging some triggers into the audio in of a filter you already have with resonance just at the edge of self oscillation.
VinceL
Post by VinceL » Sun May 20, 2018 9:01 am
Corsynth has released the DR-01 Bass Drum module which can do bass drum and tom sounds:
http://corsynth.com/home/modules/dr01
VinceL
To paraphrase Sheldon Cooper: It's MU or No U
oneunkind
Post by oneunkind » Sun May 20, 2018 1:11 pm
Paia's 5700 drum modules (pictured) and the paia Drum Tone kit (sound example) probably sound pretty different, since one is 'drum brain' synthesis style and one is 'combo organ drum machine' synthesis style.
the Drum Tone mixes some ringing filters for decaying oscillators and some filtered noise to make a few preset but mod-able drum sounds that you can trigger. it's drum voices are in the old combo organ drum machine/tr66 vein. even, uhm, rather like the 'games without frontiers' drum machine...
the suggested ladik 'twin-t' module, i imagine, is pretty dead on except for noise.
The 5700 Drum, i've only heard some pretty bad recordings of. But, it uses a VCO (NE566 VCO chip) and should produce 80s drum brain/ehx Space Drum/DS-8 type sounds. the 'synth' channels on techstar 204s/306s have a very similar feature set (with the inclusion of a vibrato, sort of useful for effects of the special type, i guess).
interested to see recommendations for what modern single modules replicate these sounds...
Goominim
Post by Goominim » Sun May 20, 2018 2:22 pm
oneunkind wrote:'games without frontiers'
Just looked that up and that example is so awesome. It almost sounds like an acoustic percussion. I'm surprised it's a PAiA.
tebs213
Post by tebs213 » Mon May 21, 2018 10:00 pm
Check out the SSF Entity drum modules, the percussion makes the most sense most likely based on your needs.
dthorn
Post by dthorn » Sat May 26, 2018 8:52 pm
Goominim
Post by Goominim » Tue Oct 08, 2019 7:55 pm
How doable is this schematic?
KSS
Post by KSS » Tue Oct 08, 2019 10:35 pm
The DIY article to build this is in the May and June 1980 issues of Radio Electronics magazine. Which are available as PDF's at www.americanradiohistory.com
I wouldn't call it a beginner's project, but it's not especially hard to make either. Just some weird layout choices in the PCB and overall construction.
The sound is like an SDSV, and the only difficulty will be getting the 566 VCO chip. The needed 3080 is also discontinued, but readily available.
As for something like this, check out the syncussion clones and SDSV clone modules.
There's a recent announcement of an SDS3 clone which will run circles around this and most any other early drum synths.
There were quite a few DS7 and 8 clone modules some years back which may be good enough for your needs.
Another good option which should be easy enough to find are modules based on Thomas Henry's percussion projects. Suggest this as first path taken.
Dcramer
Post by Dcramer » Tue Oct 08, 2019 10:59 pm
I was able to find a set of these, very cool as I had a Synare as a kid. :party:
jorg
Post by jorg » Wed Oct 16, 2019 4:02 pm
If you're up for minimal DIY, check out this from a fellow DU-er!
viewtopic.php?t=222182&highlight=
EATyourGUITAR
has no life
Post by EATyourGUITAR » Wed Oct 16, 2019 4:55 pm
ebay
acidbob
Post by acidbob » Thu Oct 17, 2019 2:02 am
Michigan synthworks released the SY0.5 not too long ago (eurorack)
The old MFB drum machines also comes close to this.
Not a module but http://mfberlin.de/musikelektronik/301pro/
