it's your money (a collection of noise tracks)
Discussing gear, production, and ideas for making noise music. Enough JMJ, let's rock like Merzbow!
nmarcoux
Post by nmarcoux » Fri Jun 08, 2018 7:04 pm
Here are a couple tracks I'm pretty psyched about. I hope you like them.
It's mostly eurorack, pedals, feedback, and samples of that commercial that's like, "It's my money and I need it now!"
[bctrack]2383556850[/bctrack]
[bctrack]493761693[/bctrack]
FetidEye
demonic space drone
Post by FetidEye » Sat Jun 09, 2018 3:02 pm
:sb: :sb: I like your sound! refreshing noise!!
nmarcoux
Post by nmarcoux » Sat Jun 16, 2018 7:15 am
Thanks! I'm curious what you mean by refreshing, if you don't mind elaborating.
FetidEye
demonic space drone
Post by FetidEye » Mon Jun 18, 2018 1:17 pm
well, a lot of noise music that I listen to has a certain sound..
and your tracks lay outside of that spectrum. so that is refreshing!
It sounds harsh, yet cleaner than most . the modular is very "there", if you know what I mean. I like this very much!
how did you record this? and did master the end result?
nmarcoux
Post by nmarcoux » Tue Jun 19, 2018 6:17 am
Awesome, thanks.
A lot of it was recorded straight into a Sony PCM D50. Modular, pedals, and DIY noise circuits routed through a small mixer (sends/returns used for modular and pedal feedback) and into the PCM. Samples mangled and played from a computer fed into the modular for processing. Recordings from the PCM were chopped up and edited in Live and and often sent for another pass through the modular and pedals.
I did a simple mastering job in Live with a bit of eq and compression, mostly OTT compressor and the stock eq plugin.
Return to “Synth Noise”
