I want 8 ins from euro to DAW and 8+ outs from daw to euro..
Author I want 8 ins from euro to DAW and 8+ outs from daw to euro..
hemeroscopium
The question is : what combination of ES modules will get me there. And what's the difference of Analog Input vs rest on ES8 ?
Sorry if its dumb @_@
Shledge
Can plug any ADAT box into the ES8 to get more inputs/outputs.
@erenod Do you want to use another USB/Firewire/Thunderbolt audio interface as well? Or just the modules?
hemeroscopium
Hello, just the modules.
Then you want an ES-8. Plus an ES-6 if you want more than 4 inputs. Plus an ES-3 if you want more than 8 outputs.
hemeroscopium
Thank you very much. I understand that i need to plug em together via ribbon cables and adapt from the front?
The ES-6 needs a ribbon cable to either the ES-8 or ES-3. Otherwise connection is via ADAT.
So you can for example have ES-3 & ES-6 together, located some distance away from the ES-8, if that's convenient.
hemeroscopium
Okay, now all is clear. Thank you very much and have a nice day smile
hemeroscopium
Now the other way around.
Using just Silent Way + Focusrite Scarlett 18i20
If i understand correctly i'd just need cables from line to eurorack?
What is/are the drawback, if any at all?
Sorry if its stupid and answered before but i coudn't find anything straightforward enough in search...
The Scarlett isn't DC coupled so you won't be able to use it with Silent Way.
