18-channel DIY Stereo Analog Vocoder
MUFF WIGGLER Forum Index -> Music Tech DIY Goto page 1, 2, 3, 4  Next [all]
Author 18-channel DIY Stereo Analog Vocoder
glubsch
Hello wigglers!
What do think about this 18-channel analog stereo vocoder?
https://www.youtube.com/watch?v=yvwQLsDnUX4
As I am new to this forum, HTML is not enabled for me (yet), so I can't embed the video here.
I've been working on this project over the last couple of years but now it's time to check the community's interest. Over time, I hope we get to know each other better on this thread.
whoop_john
glubsch wrote:
Hello wigglers!
Quite amazing! Love it. Look forward to your explanation in due course.
HighLordFixer
use [video] tags
remove the S from htttps for showing video
btw
looks und sounds Wunderbar!
post more info
that reminds me of the EMS3000 vocoder
yet possibly even better in some ways
DIY you say?
details!
prices!
people around here will want making that vocoder!
http://vocoder.hoerold.com/
http://vocoder.hoerold.com/sources/Vocoder_brochure.pdf
AntonWoldhek
that looks sick!
widdly
The vocoder sounds fantastic!
mrtweed
that is awesome!
Leverkusen
glubsch wrote:
Hello wigglers!
Welcome!
I think it sounds and looks great! I like the stereo feature and find that the voice/unvoice detection sounds very good. Also I like its clean compactness and UI design. If I can afford it (PCB's? panel option? Full kit?) I would be interested in building one.
On a sidenote: As far as I know Kraftwerk are a bit picky with usage of their music by other people. So I hope you won't get into any trouble with your video.
BugBrand
Good work indeed!
I hope, if/when you offer kits, that there will be rack mount option - or perhaps the case has optional rack ears?
[in the PDF - you could drop the use of 1/8" -- 3.5mm minijacks are not 1/8", it is just wrong terminology continually used by many people...]
Seaweed Sound
Amazing build and great demo!
hox3d
Would bananas fit instead of jacks ? razz
paterursus
I would love to see more information on this - build docs / BOM. But I would definitely be interested in a PCB/panel/case set if I could swing it. Great work on this!
abelovesfun
Sounds great. I would be interested!
tobb
WOW,awesome,much better then kit J.Haible ever did.
I am interested for sure.
Croodey
It's peanut butter jelly time! nanners Rockin' Banana!
Great job,....!!!
I'm in if you start
I'm really interessted and I can't wait love
glubsch
Lots of comments. Keep 'em coming!
Instead of quoting each post, I'll try to summarize them here in this post. Unfortunately I am not allowed to use HTML to make this post more readable.
I can't comment too much on the EMS3000 as I have no way to compare it side by side with my vocoder. I can only judge from sound samples available on youtube and there aren't that many. I would expect, however, that the VoIS (that's how I call my vocoder in short) has better intelligibility. My first attempt was to build the analysis/synthesis section using the LM13700 but that beast added a lot of noise to the system and the freezing feature didn't work too well due to the way the current output of the OTA charged the holding capacitor (for the sample & hold feature). Besides, the EMS3000 doesn't provide you a stereo option. In fact, as far as I can tell, there's no analog vocoder out there that offers you stereo unless you buy two identical vocoders :-)
Let's get one thing out of the way: there are no plans to sell a DIY kit or to organize a group buy. The VoIS is literally built using about 4000 components and I can't possibly organize this. I do, however, plan to provide the bill of materials (BOM) with a suggested distributor for each and every component, including the order code. That should help you build your order lists quickly. I've tailored that list for ordering from distributors from Europe but it should be fairly easy to adapt for those who plan to buy components from the US. In fact, in some cases it was cheaper for me to buy components from one distributor in the US instead of Europe.
Oh, and about the 4000 components: I mean it when I write "for the ambitious enthusiast". From procurement/availability point of view though, you may actually be surprised about the use of well-known components that are easy to get such as, of course, the TL074. Zoom in at the analysis/synthesis channel filter board on the dedicated vocoder web page and you'll notice the parts in use. And since I am already on the subject of availability, to keep the noise at a minimum, I chose the MC33079P for the 8-pole filters but you can just as well use the TL074 if you prefer (I've tested it).
If the number of components sounds intimidating, don't bail on me just yet. I have prepared a mono version of this vocoder without internal excitation, patch bay, and silence bridging. If you feel the high-end option is out of your reach, please bear with me. I will revisit this option once I have collected enough input from the community here. The mono option I have in mind has about 2600 components.
In general I am thinking of selling a combo of PCBs and the front panel, probably starting out with a limited run of 12 sets (PCB + front panel) to get this going.
Regarding the question about the rack mount: I was definitely planning to sell the front panel with these "ears" as you called them. Here I'd need some feedback on where to find the proper dimensions. I assume that most of you would like the regular front panel for rack mounting purposes, so that's the way to go. As far as the case goes, the screw holes are made to fit the rack case "Slim Line 03/230 3U 4mm" from HiFi2000.it. At this point I need to make clear that I am not affiliated with any suggested sources and you may choose to buy components elsewhere. But in this particular case I wanted to make sure things combine seamlessly. The channel boards are designed with a notch to hold the top cover of the case in a way that the 3 mm front panel doesn't bend, e.g. when you pull the plugs from the front panel. By the way, I got my panel done at Schaeffer AG.
I plan to release details over time as I prepare some more documentation so you get a better feel about this project. In the next step, I will provide a general overview about the parts used, such as resistor specifications, capacitors (e.g. 1206 SMDs are used as blocking capacitors). It will also contain some comments about the procurement of the potentiometers.
Regarding the comment about Kraftwerk being picky about using their music, let me be very clear: we did not use any sound snippets from Kraftwerk. All sounds are generated on our own analog synthesizer. And if you compare the simple demo with the original, you'll notice quite some difference. So I hope that's no basis for getting in trouble with them. The purpose of the video is merely to demonstrate the capabilities of the vocoder.
About the use of 3.5 mm (1/8 in): I know there's a bit of a difference between the 1/8 in = 0.125 inches and the 3.5 mm that actually convert to 0.138 inches but I thought it was common to use 3.5 mm or 1/8 inches for these types of plugs. Should I just remove the "1/8 in" from the vocoder brochure?
Regarding the use of banana plugs: I suppose you asked whether you can use them for the patch bay instead of the regular 3.5 mm patch cables. I guess you can use them if you file them off. :-) Seriously though: the plugs in use (CL1384 or the higher-quality CL1384G) have an internal switch. If nothing's plugged in, the CV-in is directly supplied internally with the signal from CV-out. In case you plug in a patch cable, the CV-in is disconnected from the internal connection and supplied via the patch cable from a different CV-out instead.
HighLordFixer
Take your time considering it is an "Epic" Project
my comment regarding the EMS 3000 Vocoder
was merely noticing some similarities from designing software emulation of that unit
all the good ones plus 18 bands instead of 12
you have an eager audience here for your R&D
some of us may actually comprehend:
you could maybe even sell individual DIY PCBs
(such as the band cards plus contemplate making eurorack powered modules(w/ faceplates) from your PCB cards)
you could possibly completely tap into that market
keep focusing on BOM & schematics
plus Banana jack or 1/4" are what ever the person building vocoder can make happen in their case or rack
(it's really a "no braininer" swapping jacks wiring direct from PCB mounts)
Thanks for responding
BTW welcome aboard here @MUffWiggler
if you need some brainstorming feedback...
you have our attention
We all eagerly & patiently will wait for any updates on this DIY Super Stereo Vocoder project!
JanneI
Great project! About the component count, many of us have sourced and build something with +4000 components, so bring it on! As long as the docs are decent, I'll be waiting for sale of your pcb's! But before that happens, I should really finally start building the Haible vocoder ;-)
MechaSeb
What an introduction ! hyper
Welcome on Muff and thanks for sharing this great project with us.
It sounds very good !
One question regarding the stereo function. Does it actually pan the odd & even channels independantly ? By listening the sounds demo, it's how my hears interepreted it... but i may be wrong of course.
Please count me in for a PCBs + front panel set when everything is ready . thumbs up
EDIT: just saw there is a brochure on your link.
Gonna check it.
LektroiD
I LOVE vocoders!
I've built a MFOS vocoder and in the process of finishing the Haible vocoder.
I'd love one of these provided it's at the right price (a few DIY projects lately have been a little too heavy on the wallet).
If anyone is doing rack enclosures like that EMS 3000, I'd be interested in one of those too!
wiperactive
Been waiting for something like this. The Haible Vocoder seems to be more of a challenge, on the face of it, for someone of my DIY build experience.
Like LektroiD has just mentioned, provided it's not too heavy on the wallet, I'd be interested in the full version. But if, at this juncture, it's too financially demanding, I could reluctantly go for the mono version without the internal excitation... glad this option may be offered as well.
Sounds spot-on in the demo!
efexor
That looks wonderful.
Eric the Red
This is just a beautiful product. If I didn’t have a Vocoder in the PCB Pile, I would be jumping on this.
glubsch
Regarding the question about the stereo functionality. To make sure no one gets a false impression, I explain this at two points in the vocoder brochure:
1) On page 3 ("Operating Principle"), there's the sentence "A unique feature of this vocoder is the synthesis of a stereophonic vocoder output from the stereophonic carrier input as each individual frequency band is assigned to one of the audio channels."
2) On page 8 ("Technical Specifications") in the footnotes: "Each bandpass is assigned either to the left or right audio channel of the vocoder output via internal jumpers".
This means that you choose for each analysis/synthesis channel filter board whether it is assigned to the left or the right channel. I've simply chosen to assign them alternating left and right going from one frequency to the next. In other words: 120 Hz is assigned to the left channel, 150 Hz to the right channel, 190 Hz to the left channel, 240 Hz to the right channel, and so on.
So there's no handling of two audio channels on each single channel filter board. If I had designed it that way, it would have been truly two separate vocoders in one rack. When I designed the VoIS, I first didn't know what I would end up with so I gave it a try. In the end, I was very pleased with the results. It's actually quite impressive how the brain works because you could argue the frequency bands are too far separated that way, the combination of all channels not providing a nice contiguous band in the frequency domain.
As far as the discussions about the rack go, I already wrote a few words about it in my previous post but let me focus on that a bit more: I don't know about all the various racks available on the market. I decided to optimize the PCB's to fit the rack offered by hifi2000.it because I've read a lot of good things about them in various posts in the past. The front panel I plan to offer (in the final version with the regular sized front panel that includes the "ears") fits them perfectly. If someone could steer me to a document that provides me with the official dimensioning of rack front panels, I could try to find out two things: 1) the standard dimensions of the front panel and the dimensions and positioning of the ears, and 2) whether the screw holes are the same for any rack option. I need to find out if the latter is also standardized.
glubsch
You know how it is: the only thing better than owning a vocoder is owning two vocoders :-)
Satanoid
Looking really interesting, but I'm already running out of space.
Page 1 of 4
