ES-8 Audio Input Expansion
Author ES-8 Audio Input Expansion
toneburst
I must admit, I'm a little confused about the various Expert Sleepers expansion options.
Is it possible for me to expand the number of audio-rate inputs on my ES-8?
a|x
Yes, with the ES-6 (and once you have an ES-6, with an ES-7).
toneburst
Ah, OK. That makes sense.
I was wondering really if there was an expander that could be connected to the ES-8 via an expansion header, so that the extra input channels could be used while the ES-8 was connected to an ADAT host like my MOTO 828 (ie without the USB being connected).
I guess that's not possible, currently.
a|x
Indeed not.
For that you would want the ES-3/6/7 combination.
cloudleft
I have a related query. I'm hoping to use the 8 ADAT channels from my MOTU ultralite to expand the inputs on my ES-8. Is that possible?
Currently, via the MOTU config app, I'm routing the 8 analogue inputs on the MOTU directly to the 8 ADAT output channels. (Analog 1 -> ADAT 1, etc.)
However when sending a signal through ADAT 1 into the ES-8, it does not appear at the corresponding ADAT input on the ES-8 (in this case, "input 5", as its labelled in macOS Audio/MIDI setup).
If this can't be done, is the reverse possible, i.e. sending ADAT out from ES-8 into the MOTU?
The goal is to maximize inputs for monitoring multitrack recording. Anyway, thanks!
Do you have both interfaces connected via USB, or is one of them operating standalone?
I take it you have an ADAT cable connecting the MOTU ADAT output to the ES-8 ADAT input?
cloudleft
Hi Andrew, thanks. Right now, both devices are connected via USB.
And yes, MOTU ADAT out -> ES-8 ADAT in
In my device setup, I've tried running them as an aggregate device, and also as 2 separate devices.
That should work. Have you set the ES-8 to sync to the ADAT input?
michi
... in osx 10.13
audio/midi-setup shows 4 analog ins and 4 adat ins.
only the ins on the es-8 are working.
i have connect the expansion cable and the power cable for both modules and i dont know what is wrong.
michi
I would check the ES-8 is getting enough power. Maybe removing some other modules from the case temporarily.
michi
this helps not - i have testet with +12/-12V@1A & +5V@300ma only for the es-8 and es-6
Have you connected an ADAT cable as well?
michi
no - i think the connection is thru the connection cable?
No, you need both.
michi
o.k. - this was a bit stupid :-) great thanks
have you a idea where to get a very short adat cable?
the shortest i have seen was 1m
Expert Sleepers do them: http://expert-sleepers.co.uk/accessories.html
So contact your local dealer.
