PCB contact melted down / burned! Where to jump to?
Author PCB contact melted down / burned! Where to jump to?
minipusice
Hi there,
I have overheated and melted the contacts on board when re-soldering the Resonance pot on my Befaco BF-22 filter. Now I am trying to figure out where exactly to strip board to copper an re-solder two challenging pins with little jump wires. Could you please help?
I have attached a pic and indicated two connectors that I have burned...
Thanks,
K
lasesentaysiete
that is what is known as a "lifted pad". You should follow the traces to the connecting component or check the schematic. You may still be able to solder in the missing component on the other side of the pcb because it is double sided.
minipusice
Thanks so much!
Found the schematic. Seems pretty straight forward.
Cheers!
