470pF polyprop. 1% - source? (Europe)
Author 470pF polyprop. 1% - source? (Europe)
mmeixner
Hello!
I'm just going trough my Oakley backlog, and for the SVF I need two
470pF, 63V 1% polypropylene
It's not easy to find these with 1% - somebody has a source (Europe), or a part number, or an alternative?
And since I misplaced the PTCs I had ordered for my two VC-LFOs: has somebody a source for these (Europe again). I had the idea to just use SMT- parts and mount them ... is this a bad idea?
Thanks for info
Synthbuilder
You can also use 470pF C0G ceramic capacitors with a lead spacing of 5mm in place of the polypropylene capacitors. Indeed, since I wrote that Builder's Guide eight years ago the availability of good quality ceramics have spread while other types of capacitors have dwindled. I think I'll update it today.
Temp co resistors - the smaller ones - can be got at Farnell:
http://uk.farnell.com/te-connectivity-citec/lt300014t261k0j/resistor-t emperature-sensing-1k/dp/1174306
Tony
mmeixner
Synthbuilder wrote:
You can also use 470pF C0G ceramic capacitors with a lead spacing of 5mm in place of the polypropylene capacitors. ...
I have to order still more Oakley PCBs :-)
Schlumpfhut
When i was building my SVF i got my polypropylene caps from banzai with the required tolerance
https://www.banzaimusic.com/WIMA-FKP2-1-470pF-63V.html
Not the chepeat source but the only one i was able to find.
