Low Cost PSU current
Author Low Cost PSU current
Ernst Bitter
Hi,
I´ve built this nice little PSU
http://www.modularsynth.ru/en/diy/low_cost_psu/
which works fine so far. Now I´d like to know how much max. current it could handle on the 3 power rails when I use a 12V AC with 1A.
Can anyone help me to find out?
Synthbuilder
A little over +250mA for the sum of both positive rails, and -250mA for the negative rail.
The DC current in each rail is roughly about a quarter of the supplied AC (rms) current. Since the latter should not exceed 1A that will give around a maximum load of +/-250mA of DC current.
The +5V rail's current needs to be taken from the same supply that feeds the +12V but with just a 75L05 in there you'd be lucky to get much more than 40mA out of the 5V before the 78L05 got really hot and shuts down.
Tony
Ernst Bitter
Thank you!
