Author |
FH 1 trouble - stop converting |
br>nemox |
br>Hi os,
Here is my post issue as requested.
I bought a FH 1 few months ago that I use with my digitakt.
The problem is it often stop converting the digitakt messages.
It seems to still receive the clock but it doesn't transfer anything to the modules.
This can happen without any reason, when I patch/unpatch on the FH 1...
When it happens I have to switch off the case for few minutes/hours before it works again.
I got this problem with the 2.0 and 2.1 firmwares.
Any idea on how to solve this problem ? br> br> |
br>os |
br>What is happening that makes you say "It seems to still receive the clock"? br> br> |
br>nemox |
br>The leds A-H and 1-8 are blinking (A-1, B-2, etc.) in sync with the digitakt clock. br> br> |
br>os |
br>OK, so it's still receiving MIDI messages.
Are you using a config script on the FH-1? If so, can you post it here? br> br> |
