Part confusion - 1/4 In. Switching Jack?
Author Part confusion - 1/4 In. Switching Jack?
Eric the Red
Getting confused on Mouser... can someone point me to a 1/4in Switchcraft Switchcraft Jack?
Building 10 Barton VCA Mix’s, and I’ll need quite a few of these.. http://www.bartonmusicalcircuits.com/vcamix/documentation3.1.pdf
Thanks guys!
fuzzbass
Switchcraft 112BX is a switched, 1/4 inch TS panel mount jack. It has a partially enclosed back.
sduck
I always use 502-112AX ( https://www.mouser.com/ProductDetail/Switchcraft/112AX?qs=%2fha2pyFadu jWCy1pI0yQkPWxDpAw%252bSj2%252bkEUXFO9k2M%3d ) from mouser for basic switching jacks. You can use this page to decide which kind you need - https://www.mouser.com/datasheet/2/393/n110x-mn110x_series_cd-475943.p df
Eric the Red
Thanks guys!
unrecordings
112AX here too - these have the little solder eyelets
112APCX is the same kind of mono switching jack but with flat lugs for soldering onto a board
Fuzzbase - are you sure 112BX is switched, I'm fairly certain B is open circuit and A is switched ?
Here's a schematic:
fuzzbass
Here's a schematic:
Um... Having now consulted the datasheet that sduck pointed us to, I can say with confidence that 112BX is WRONG! d'oh! 112AX is the correct configuration. My apologies to all.
