[SOLVED] CEM3340 Troubleshooting
Author [SOLVED] CEM3340 Troubleshooting
Tristana
Hello all,
I've been attempting to make a CEM3340 oscillator, following this circuit from LookMumNoComputer (cross-referenced with the datasheet):
Source: https://www.lookmumnocomputer.com/projects/#/cem-3340-diy-simple/
However, my oscillator I've assembled on a breadboard seems to be very quiet and perhaps high-passed. You can hear what I mean here- this is with +24dB of gain applied in my DAW-
https://www.dropbox.com/s/g7m93u589qvujcm/cem3340_sweep.wav?dl=0
Any ideas as to what I've done wrong? I've redone the circuit from scratch a few times now, each time with the same resultant sound.
l3v3l6
Can you put a scope on it and see what the output P2P voltage is?
guest
check the powersupply connections on your breadboard. sometimes the rails arent connected for the full length (see where there is a break in the red and blue stripes - that might need to be jumpered).
Tristana
... derp, that was it! Thank you!
guest
cool, glad it worked. i remember the first time that happened to me, it was super frustrating.
