pre-drilled panel source
Author pre-drilled panel source
floris
What would be the fastest and least expensive source to buy a few pre-drilled aluminum panels for my diy serge?
The panel needs to fit a normal bud board.
And I'm in Belgium, Europe.
julian
If you need them to be accurate, probably me! : )
If you don't need them that accurate then visit your local engineering place, and explain your situation. If you don't need them that precise, they should be pretty cheap, but the more precise you need them the more anyone will charge.
bgreeves
Check out Front Panel Express. Probably very accurate, but not very cheap for one-off designs
floris
thanks for the input!
