Output level gates MOTU Ultralight MK3
Author Output level gates MOTU Ultralight MK3
jessemiller
The only way I can get enough voltage output from my MK3 interface when using the Silent Way Voice Controller is to put it through a VCA in my modular rack completely turned up.
MK3 is showing 100% output in the LCD screen, am I missing some way to make that voltage greater?
A mk3 should be able to give you about 3.5V, which is less than a normal Eurorack gate but should be enough to trigger most things.
Have you measured what you're getting?
