Roland Space-Echo input mod question
Author Roland Space-Echo input mod question
pustule
I recently saw a post by EchoFix on instagram (HERE) explaining that they modded the instrument input to be "both guitar and keyboard friendly".
I've noticed that it's very easy to max my RE-150 out when using it with my Buchla modular synth, so i'm interested in having something like this done to my space echo.
I'm wondering if anyone has any info about what might have been done to it? I tried contacting EchoFix, but they (understandably) wouldn't give me much info because they mod these things as a business.
Isn't the whole notion of an "instrument" input designed to be used with line level signals? Or was this instrument input meant to be mainly used for guitar's?
abelovesfun
According to the manual here: http://dl.lojinx.com/analoghell/RolandRE150_OwnersManual.pdf The Instrument input appears to have been meant for mixer effects sends, so: line level (less than modular).
pustule
Ah, good to know. I was under the impression that a Buchla audio signal was line level even though it's a modular synth, but maybe it's still louder then typical mixer signals... Do you suspect that this mod has some sort of attenuation on the instrument input then?
papz
An easy way to do it is adding a resistor between the input jack tip and ground.
I did it in my RE-20 pedal years ago because its outputs got overdriven too easily with my Synthi.
From memory I used 10k, but you can experiment with various values to find what best fits your needs.
The lower the resistance the higher the attenuation of the input signal.
pustule
Thanks for the idea Papz! That sounds easy enough ;-)
