Mellotron M400 Motor Replacement
Author Mellotron M400 Motor Replacement
orchestron
Hi all,
I'm working on a Mellotron project and looking for a number of replacement parts, first and foremost, a new motor. Could someone please kindly recommend a motor manufacturer/model number that is compatible with the mellotron?
I've read that the mellotron used a 24 volt motor. Is this correct?
Thank you in advance.
Hi,
You may very well be aware of this but in case not you should contact the followiong two companies and see what they would charge you for the parts you need? cool
mellotronics.com
mellotron.com
