DIY Sequencers?
Author DIY Sequencers?
skiddlydatdoot
What's the most advanced DIY sequencer? Has anyone tried to build one with something like a Raspberry Pi?
secrethero303
It isn’t out yet but I think this will be one of the more capable DIY sequencers when it comes out. https://m.facebook.com/performerseq/
skiddlydatdoot
Looks like exactly what I wanted; a DIY Eloquencer. Thank you!
latigid on
https://www.midiphy.com/en/mbseq-v4-/
flts
My vote goes for Midibox Seq V4 as well. Pretty amazing feature set, various versions have been in development for 15 years now (v4 for 10 years) so it's getting pretty mature now. The Midiphy V4+ version is looking awesome.
Of course, you didn't specify if you meant Eurorack sequencers or DIY sequencers in general, that one is a standalone device.
aabbcc
That indeed looks very awesome, tempted to get a kit. Now if it onyl had CV/GATE outputs that would have been amazeballs.
flts
It has the line driver module and port integrated, which I take to mean (latigid on can correct me on this) that one can pretty easily build a separate module / box with one or more of the Midibox analog (AOUT series) and gate/trig output (DOUT) PCBs, and connect that to the main sequencer via a DB25 breakout cable.
TL;DR: it looks like at least the hardware is ready for the CV/gate outputs, you just have to build them separately to another case.
aabbcc
THanks! Yea I checked the midibox forums and you are correct about that!
All though a rough estimate fir the kit, components and case was 700eur on the midibox forums, and that's without the cv gate, might as well get a Social Entropy Engine for that amount :(
flts
Yeah - it's sort of premium quality components all the way. The standard V4 that is already available as parts here & there (no complete one size fits all kit) will most probably be a lot cheaper to build but you need to figure out some things yourself, including the case (panels are available).
Jaytee
Social Entropy Engine isn’t a DIY project though?
Keep digging on the MIDIbox Seq. The MIDIphy version isn’t the only one, and because of MIDIbox’s modular nature (not modular in the specific synthesizer sense, but in a more general sense), you can build a MIDIbox Seq to almost any price point or specification you like. The MIDIphy kit is just the most recent example, and is designed for beginner-friendliness and a slick finished product, rather than cost.
skiddlydatdoot
This is really nice, if the Performer Sequencer didn't exist I'd probably consider this with some sort of midi to cv solution. Thanks for sharing.
ersatzplanet
What sort of sequencer are you looking for? If a simple step sequencer but effective and at a small cost works, then check out the Division6 Dual Mini sequencer. Two 16 step sequencers with a CV and accent out in one small panel and only $35 for the PCB, Front panel and Preprogrammed ICs, $90 for the full kit of parts. All through hole.
https://division-6.com/products/dual-mini-sequencer/
