Oakley ASV: Complete Synth Voice for 5U
Synthbuilder
Post by Synthbuilder » Sat Nov 17, 2018 11:29 am
This is for folk who like to build their modules.
I have circuit boards available for my new Analogue Synthesiser Voice module.
And a quick picture of the reverse side showing the four printed circuit boards.
More information, including sound samples, at the usual place:
http://www.oakleysound.com/asv.htm
I'll be updating the above page with photos of the boards in more detail, as well as adding a User Manual and complete Builder's Guide in the next few days. Currently the Builder's Guide has just the parts list but it'll give you an idea of what's needed to build the project.
Here's something I knocked showing what you could do with just an ASV, some reverb and delay, and Nord A1 doing the strings. All done live with the lead and strings done as an overdub. The sausages were under the grill which made me work quickly:
http://soundcloud.com/takla-makan/asv-track
Tony
Leverkusen
Post by Leverkusen » Sat Nov 17, 2018 1:04 pm
Hooray!
There it is. Finally! I like your sausage sounds and just ordered a set of PCB's - together with a delay and a phaser, which should make a nice team...
:sb: :party: :guinness:
Revok
Post by Revok » Tue Nov 20, 2018 7:56 pm
The demos are all so good. This thing sounds awesome!
Dave Peck
Post by Dave Peck » Tue Nov 20, 2018 8:38 pm
Looks great, I nice alternative to a SEM! How easy would it be to add three additional patch points for LP out, HP out, and BP out? This would really open up the possibilities of the filter when using it in a larger modular by allowing you to do things like patch various filter outputs to crossfaders, adding CV control of filter modes. Or pass the different filter outputs through various other processors like phasers or whatever and then re-combine them, etc.
Also, do you have artwork for an MU panel?
Or do you know if this will be offered by Krisp1 as a pre-built MU module?
Synthbuilder
Post by Synthbuilder » Wed Nov 21, 2018 2:51 am
Dave Peck wrote:How easy would it be to add three additional patch points for LP out, HP out, and BP out?
There's no dedicated patch points on the main PCB but you could hack some additional outputs from the filter outputs. They are all buffered so it wouldn't be too difficult to do. Of course finding space on the jack field will be tricky.
Ultimately, working out what to keep and what to remove was the hardest part of the design. Trying to cram so much into a 5U or 4MU wide panel is bound to leave some folk disappointed. In the end I chose what I would like and tried not to think about all the other possibilities. Remember though that this is a modular unit. One could route the Mixer Out to an external SVF and then back into the ASV's Filter In for further processing fun.
I don't yet but the MOTM and MU layouts are identical. I am planning to have some MU panels made. I will be asking Ben to look into this for me shortly.
Two of these should sit side by side in a Box 11 with some space for some extras like a midi-CV convertor or sequencer.
Not sure yet.
Tony
Dave Peck
Post by Dave Peck » Wed Nov 21, 2018 2:53 pm
I think you made some good choices about what to include! Especially the audio rate filter FM, and the triangle wave that bypasses the filter. Nice.
Yes, it looks like the question of where to install new patch point jacks will involve some head scratching... You could probably still use the jack field PCBA and install some new Switchcraft 112 jacks through new front panel holes located between the existing jacks, and bend the solder tabs over on the new jacks so they don't hit the jack field PCB... or maybe install the new jacks in some adjacent module, like a spare multiples module....
krisp14u
Oakley4All!
Post by krisp14u » Wed Nov 21, 2018 5:01 pm
If I get enough interest I will make them for sure :banana:
I would need quit a few solid orders as I cant afford to build this if it sells at the rate the last 2 modules I released have :ripbanana:
I will be starting my own build as soon as the boards get here in the morning :bananaguitar: :bananaguitar: :bananaguitar:
Cheers :guinness:
Paul
www.krisp1.com/store/
Fine Modular systems Built in Yorkshire UK EU Planet Earth
Rex Coil 7
Re: Oakley ASV: Complete Synth Voice for 5U
Post by Rex Coil 7 » Wed Nov 21, 2018 5:23 pm
Synthbuilder wrote: .... I have circuit boards available for my new Analogue Synthesizer Voice module.
Tony
:woah: :hail: :eek: :hail:
Revok wrote:The demos are all so good. This thing sounds awesome!
That's no lie! The ~lead~ sound in the Sound Cloud file posted (attached) above reminds me of a well known Klaus Schulze video ... (the part I'm referring to comes in at around 6:50 minutes) ...
Dave Peck wrote:Looks great ...
Sounds even better.
Dave Peck wrote:nice alternative to a SEM!
This new Oakley is easily destined to be known as a classic, and soon.
Dave Peck wrote:I think you made some good choices about what to include! Especially the audio rate filter FM, and the triangle wave that bypasses the filter. Nice
Spot on.
:cookiemonster:
Post by JohnLRice » Wed Nov 21, 2018 6:56 pm
josaka
Post by josaka » Wed Nov 21, 2018 7:03 pm
Everyone will want one I think...be curious to see the price point..
..for this all-in-one module ..its the key in this post behringer landscape..
looking lovely.. ! :)
Post by JohnLRice » Wed Nov 21, 2018 7:33 pm
I was just thinking, while special cables could be made, if the jack board connectors were doubled up it would make if very easy to plug into a future Oakley or third party programmer module? The programmer would only make the interconnections of course, not pot or switch settings, but could be a handy thing? It could be just something simple like a single rotary switch and many banks of jumpers, DIP switches, and or a pin matrix to 'program' each 'preset' or something fancier that would provide for Gate and/or MIDI selection of presets and more memory locations? Or at least the connection points might make it easy to integrate many of these modules into some larger systems? :hmm:
Synthbuilder
Post by Synthbuilder » Thu Nov 22, 2018 4:16 am
JohnLRice wrote:Or at least the connection points might make it easy to integrate many of these modules into some larger systems? :hmm:
I am hoping to develop a polyphonic voice card at some point. One panel multiple volces... but I have no time scale on this. The next thing on my 'to do' list is a fully polyphonic string synth. The Oakley MAP is also ongoing.
Tony
Synthbuilder
Post by Synthbuilder » Thu Nov 22, 2018 4:22 am
Dave Peck wrote: You could probably still use the jack field PCBA and install some new Switchcraft 112 jacks through new front panel holes located between the existing jacks...
Sadly there is no room for any more sockets on the PCB. There is only 6mm or so between the plastic outer shells of each socket. You could get the sockets closer with a new layout - a single MU width module can carry three sockets across its width. But I'm not a huge fan of that level of density.
Tony
Synthbuilder
Post by Synthbuilder » Thu Nov 22, 2018 4:33 am
josaka wrote:Everyone will want one I think...be curious to see the price point..
Indeed. Uli has managed to get the price of the Model D down to nearly 260 quid here in the UK. That's amazing really and about the price of a single 5U VCO module. If one compares just the raw features then the Behringer will win all the time. Build quality, longevity and ease of servicing may well be different. But a hand made device will never be able to compete in price against mass manufacture.
I'm hoping that the ASV will encourage a few more folk to get into building their own synths.
Tony
Post by JohnLRice » Thu Nov 22, 2018 4:56 am
Tony
Sounds good! :tu:
I was thinking further after I made that last post that there is no need to modify anything to your existing design . . . someone wanting to make a preset capable synth could just skip the jack board and panel all together and then have a big keyboard case with 3 to 8 :hyper: of the main PCBs behind it's panel and then long ribbon cables connecting them all to the master computer controlled patch matrix / memory / sequencer section! :cloud: I know, this would be quite similar to the Oberheim 2/4/8 voice keyboards with SEMs and a sequencer etc but . . . :hihi:
hamildad
Post by hamildad » Thu Nov 22, 2018 8:16 am
Synthbuilder wrote: The next thing on my 'to do' list is a fully polyphonic string synth. The Oakley MAP is also ongoing.
you still planning an analogue Delay? that was going to be my only exception for 'NODIY19'
My Synth Instagram here * My Synth videos here
External PSUs and DC jacks are the hallmarks of toys. - Graham Hinton.
I am one of the "tiny fraction of a percentage of oversensitive idiots" who feels the name of this site sends the wrong message.
This is primarily for melody and historical educational purposes - Analogue Music
Synthbuilder
Post by Synthbuilder » Thu Nov 22, 2018 10:10 am
hamildad wrote:you still planning an analogue Delay? that was going to be my only exception for 'NODIY19'
This one?
http://www.oakleysound.com/ADR30.htm
Not 5U though. Half rack. It does have a CV input for delay though.
I may do one in 5U at some point.
Tony
hamildad
Post by hamildad » Thu Nov 22, 2018 11:43 am
Ah yes, it was the 5U versions I was thinking about.
Leverkusen
Post by Leverkusen » Thu Nov 22, 2018 2:46 pm
Tony
Delay, Phaser, Flanger, Chorus...isn't a reverb missing - a Spring, or multiple cross fed back delays - or a mix of both?
josaka
Post by josaka » Thu Nov 22, 2018 3:48 pm
Tony
yes.. cant compete with that.. the real problem is ..looking around.. over the last 30 years this idea of 'build quality' has all but gone.. look at tvs-phones-all consumer electronics.. its all cheap chinese(who make all the shit both good and bad) which has become the norm.. I think a lot of euro has gone this way and certain 5u are going.. I think if you cut 5u quality by 50% it would still last 40 years in real terms :) even then you still wouldnt be on par with ulli shame he puts that effort into stealing..
ranix
Post by ranix » Thu Nov 22, 2018 3:55 pm
Not all of the stuff made in China is cheap. Sometimes when you're making a product you have to build it in China because that's where the expertise you need for the moulding or gluing or welding or whatever weird specific thing you need to do is. The actual engineers over there who work on all these different cheap products develop expertise that allows the manufacture of more complex equipment. There are other challenges developing stuff in China though. It's a complex topic. Behringer certainly have the ability to produce top notch equipment if they want to but in my experience they tend to make compromises in the strangest places. Some real "you have to be stupid to do this" kind of mistakes.
josaka
Post by josaka » Thu Nov 22, 2018 4:00 pm
from my post.... 'everything is made there both good and bad'
ba1
5U Delay
Post by ba1 » Sun Jul 07, 2019 4:53 pm
This one?
Tony
There are sadly not enough analog delay options in 5U. I would love to see this as a module!
Synthbuilder
Re: 5U Delay
Post by Synthbuilder » Mon Jul 08, 2019 2:34 am
ba1 wrote:There are sadly not enough analog delay options in 5U. I would love to see this as a module!
It's on my 'to do' list. MU only though - probably not MOTM.
As to when it arrives I'm not sure. Folk are wanting my new Euro sequencer ported to 5U so that may come first. And currently my main priority is a whole raft of new Eurorack modules.
Tony
Faustgeist
Post by Faustgeist » Tue Jul 09, 2019 8:21 am
Great looking additions. I need to heat up the soldering iron. :bananaguitar:
Trying to build up my 5U COTK/MOTM, send me a message if you are selling gear and thanks!
Return to “5U Format Modules”
