Acid Moose - Two TM3030's in a hard-driving enclosure
Author Acid Moose - Two TM3030's in a hard-driving enclosure
tvainio
Here's my Acid Moose project. Two Oakley Sound Systems TM3030 synths built into an old Macintosh Plus hard drive enclosure.
More details and pictures in my blog:
https://noiseembedded.blogspot.com/2018/12/acid-moose-two-303-clones-i n-hard.html
Thanks for the great project and support!
Synthbuilder
Excellent work and nice to have your work so well documented. thumbs up
And a video too. Rockin' Banana!
A couple of points about drilling through steel cases.
1. Always use a drill lubricant and go slowly.
2. Swarf around the holes can be easily removed by using a much larger drill, eg. 10mm one on 6.5mm holes, or a special deburring bit. A countersink drill bit can also be used but make sure it can handle the material you are deburring. You can either spin the bit by hand or use your drill and gently press down and allow the bigger bit to cut away the swarf without making the hole bigger.
Tony
