| View previous topic :: View next topic |
| Author |
STG users need a clock module |
kindredlost Super Deluxe Wiggler
Posted: Thu Sep 09, 2010 7:35 am Post subject: |
| suitandtieguy wrote: | | Have you tried running numerology rewired to cubase, then run sync unit DC in numerology? |
I forgot to mention that I tried that too. I couldn't figure out a way to manage Sync Unit DC from Numerology. It comes up as a module but only has MIDI Clock IN, Audio IN and some other hookups which I didn't find useful for this. I could be implementing it wrong but it was fairly DOA when I tried it. At second glance I may have not tried to use the audio track method to send through Sync Unit DC in Numerology. I don't see the advantage of that over a couple of midi channels in Cubase to be honest.
Possibly, all this is a mute point now.
-David _________________ OpenTape
noises4sale
soundcloud
videos |
| Back to top |
essex sound lab wiggler of the spheres
    Posts: 2568 Location: Lenox, Mass
Posted: Thu Sep 09, 2010 8:46 am Post subject: |
| kindredlost wrote: |
Will the Time Buffer operate as if it has sync24 input to it? Midi will start and stop the Time Buffer and slave modules?
Just to verify...is this accurate? If so it's a really clean solution...and it makes it that much easier for me to begin to take the plunge on the STG Time Suite, without waiting for the other forthcoming goodies. |
| Back to top |
Posted: Thu Sep 09, 2010 1:26 pm Post subject: |
| essex sound lab wrote: | | kindredlost wrote: |
Of course I am assuming that it will.
If I read the specs on midi correctly, the "native" clock is actually 24ppq so it's just a matter of offering this to the Time Buffer in the proper pulse packet. It should be noted I be talkin straight outta' my ass, but that is my limited understanding of midi in relation to sync 24.
That is why I was interested enough to buy a Moon 553 midi module. It offers 1/96th divisions which is the same as 24ppq. Supposedly it gets this pulse from the native midi clock timing. That's where I got the notion.
The bit about midi starting and stopping the Time Buffer is still an implementation issue for Suit & Tie Guy, but it looks as if the kit offered will allow for this in some form.
noises4sale
soundcloud
videos |
| Back to top |
suitandtieguy Hammond King
     Posts: 2950 Location: Chillicothe IL USA
Posted: Thu Sep 09, 2010 3:46 pm Post subject: |
Yes it should start and stop the transport, it translates midi clock to din sync.
And I think if I'm clever enough with my wiring they could both fit on the same connector, so you wouldn't lose any functionality. If I remember right MIDI uses the other two pins. _________________ http://suitandtieguy.com
http://stgsoundlabs.com |
| Back to top |
giorgio NITE MIND
   Posts: 2411 Location: BRAND NEW YORK
Posted: Thu Sep 09, 2010 4:42 pm Post subject: |
| STG FTW. |
| Back to top |
Posted: Thu Sep 09, 2010 7:08 pm Post subject: |
| suitandtieguy wrote: | Yes it should start and stop the transport, it translates midi clock to din sync.
And I think if I'm clever enough with my wiring they could both fit on the same connector, so you wouldn't lose any functionality. If I remember right MIDI uses the other two pins. |
There could be issues with the 4 & 5 pins when in din sync mode. There are some devices that may need these for fill-in/continue and reset/start functions. Possibility that there could be a wonky behavior there.
I read this on the Blacet Research data sheets for the IC converter chip.
I have no clue whether it is for real or nothing to worry about. Just saying... it might be worth checking into.
I would be pretty cool to have both. Maybe a switched setup? Hardware crap - I know. _________________ OpenTape
noises4sale
soundcloud
videos |
| Back to top |
| Back to top |
Chuck E. Jesus holier than thou
      Posts: 2898 Location: next to Serious Fun!
| Back to top |
Posted: Wed Sep 15, 2010 11:09 pm Post subject: |
Thanks. There seems to be a few different manufacturers making this type of device. This one looks like the cheapest price.
I did get the Moon 553 Midi To Clock module today. It puts out the proper 24ppq pulse but the midi start/stop is separated into two 1/4" jacks which are a short pulse instead of a long gate ON/OFF. So I am running these to a Q962 Sequential Switch and the switch into the Time Buffer. The 1/16th notes out from the 553 is sent to the 554 Octal Clock Divider for divisions to the dotcom sequencers, LFO resets, etc..
There is a way to send midi note on from two separate regions of the midi note values to the 553 and it will act as a gate for this sync24 RUN/STOP function, but I really am trying to find a way to avoid having to generate a midi track for that.
I think this Doepfer device may actually be a better way to do it. At least I wouldn't have to burn a Q962. But now that I have an octal divider I may not ever need two Q962's anyway. _________________ OpenTape
noises4sale
soundcloud
videos |
| Back to top |
