FH-2, FHX-8GT + FHX-8CV Expanders Jumper Setting Confusion
Author FH-2, FHX-8GT + FHX-8CV Expanders Jumper Setting Confusion
toneburst
I've just bought an FHZ-8CV expander to add to my FHX-8GT, but I'm a bit confused about jumper settings.
I'd like to have the FHX-8CV as the first expander, followed by the FHX-8GT.
In this case, would I set jumpers like this:
GT
Expansion 0
CV
Expansion 1
With this setup, would I be able to use outputs of the CV and GT expanders as pitch CV + Gate pairs (ie FHX-8GT output 1 as pitch and FHX-8GT output 1 as gate), or Trigger + Velocity pairs (with ie trigger 1 from FHX-8GT output 1 and velocity from FHX-8CV output 1)?
Hope this makes sense...
The functionality is the same however you have the expanders set.
yes.
Not using the Triggers/Gates section but that's an oversight on my part. You could do it with a MIDI/CV Converter.
toneburst
Hi @os,
I've been trying to setup the trig/velocity pairs, as mentioned above, and can't work out how to do it with a MIDI/CV converter.
toneburst
This seems to work smile
Tokyo-Noise
hi.
I have two quick questions:
1) Can I use a FHX-8GT with a FH-1, or with a FHX-8CV connected to a FH-1?
2) If so, how should I set the jumpers in FHX-8GT?
Thanks.
No, you can't use the FHX-8GT with the FH-1.
progendev
And when a single FHX-8GT is the only expander connected to an FH-2 (besides the MIDI breakout), there should be no jumpers linked on GT4 of the FHX-8GT, right?
That would make it 'expander 0'. If you put the jumpers on it will use a different slot, but it will still work.
