Moon Modular patching idea's
DaviT
Post by DaviT » Thu Jan 31, 2019 11:50 am
It's almost weekend and i would love to here what you can do with this system. I always end up with a 'moogish' patch so any idea's are more then welcom!
Kind Regards,
DaviTImage
DaviT
Post by DaviT » Thu Jan 31, 2019 1:19 pm
Oops, changed the multifilter for the M554 octo divider.
josaka
Post by josaka » Thu Jan 31, 2019 1:47 pm
its the same with all 'smaller' modulars.. you need to start lateral thinking :) driving and modulating !.. modulating the filter with Audio rate signals produces interesting stuff (both res and cutoff) drive and AM/FM your VCAs..
looking at that Moon you could mult a sine(audio rate) and send it to filters/vcas
DaviT
Post by DaviT » Thu Jan 31, 2019 2:15 pm
Verry interesting, could you explain a little further. i'm still a noob' when it comes to modular. Loving to modulate stuff(enough mult's) and i know i don't put the system to her limits.. still short of VCAs , i think.
DaviT
Post by DaviT » Thu Jan 31, 2019 2:20 pm
..and thanx for the help!
Dave Peck
Post by Dave Peck » Thu Jan 31, 2019 3:20 pm
Basic example: Mult the osc signal and send it to both the normal audio input of the filter PLUS send it to a spare CV input to the same filter, in addition to however you would normally control the filter cutoff (like an LFO or envelope). This causes the audio signal to open & close the filter at an audio rate which completely changes the sound of the filter.
More complex example: Send OSC 1 to the filter's audio input and tune osc 2 to a different pitch (maybe a fifth? An octave down?) and send that osc 2 to the filter's CV input.
Even more complex:
You have two separate filters so - send osc 1 to audio in of filter 1 and send osc 2 to CV in of filter 1. And now send osc 2 to audio in of filter 2 and send osc 1 to CV in of filter 2.
OR: send both oscs to audio in of filter 1 and also to audio in of filter 2 (parallel filters) Now send the audio OUT of filter 1 to the CV IN of filter 2 (modulating filter 2 with the complex output signal from filter 1).
josaka
Post by josaka » Thu Jan 31, 2019 3:39 pm
Dave Peck wrote:Basic example: Mult the osc signal and send it to both the normal audio input of the filter PLUS send it to a spare CV input to the same filter, in addition to however you would normally control the filter cutoff (like an LFO or envelope). This causes the audio signal to open & close the filter at an audio rate which completely changes the sound of the filter.
Even more complex:
yep :) :yay: :tu: you can also get 'interesting' non musical results setting both osc to lfo mode.. pitching them in the 'growl/crackle' zone and Fm'ing your filter to get a buchcla 259 type sound..
josaka
Post by josaka » Thu Jan 31, 2019 3:44 pm
attenuating an audio rate osc (sine/square) signal into your resonance cut off input can create wonders.. also feed it via a S/H makes even more crazy :)
send a signal via the env (filter env is fine send it to a mult and then to exp FM input as well as your filter input) you can make stabby/rising sounds (horn style)
most wonderful sounding osc are using these type of routings myself and Dave mentioned to achieve most sounds.. FM synthesis is achieved like this.. as are many other sounds.. cross modulation(patch one osc into the other while synced) FM/AM, envelopes, Drive,.. play about.. on the surface it looks limited.. its not.. :)
DaviT
Post by DaviT » Fri Feb 01, 2019 3:08 am
Thank you verry much!
..Any octo divider idea's and do i have an S/H ? :hihi:
Post by JohnLRice » Fri Feb 01, 2019 6:33 am
Here's a quick simple test I did for what it is worth. :hihi:
https://soundcloud.com/johnlrice/ghosttownfiredrill
This patch only uses a Moon 524+524A quad VC LFO and a 554 Octal Clock Divider as well as a 4 channel mixer (I useda different mixer then you have) and the mixer's output is run through a couple reverb and delay effects. Then I hit record and wiggled the knobs. 8-)
DaviT
Post by DaviT » Fri Feb 01, 2019 12:59 pm
Thank you for your effort John, you're The Boss !!
DaviT
Post by DaviT » Sun Feb 10, 2019 2:14 pm
[video]
DaviT
Post by DaviT » Sun Feb 10, 2019 2:15 pm
Post by JohnLRice » Sun Feb 10, 2019 2:24 pm
Remove the letter "s" from the "https" to get the embedding to work! :tu:
Dr Gris
Post by Dr Gris » Mon Feb 11, 2019 10:53 am
Great!!!!
I love it when people do videos. I wish I was smart enough to do some...
Keep em comming :party:
Thanks!!
//M
DaviT
Moon modular Patch & Tweak no#3
Post by DaviT » Fri Feb 22, 2019 10:25 am
Dr Gris
Post by Dr Gris » Sat Feb 23, 2019 5:33 am
Nice! What happened to Patch & Tweak no#2? :mrgreen:
//M
DaviT
Here you go..
Post by DaviT » Sat Feb 23, 2019 4:11 pm
DaviT
Patch & Tweak no#4
Post by DaviT » Sat Feb 23, 2019 4:13 pm
DaviT
The last one...for now (until a later time.)
Post by DaviT » Sat Feb 23, 2019 4:15 pm
Rex Coil 7
Post by Rex Coil 7 » Sat Feb 23, 2019 6:40 pm
josaka wrote: buchcla 259 type sound..
Outstanding sounds!!
Geez ... I am FAR too stupid to even begin understanding how to work with a Buchla system.
Are you kiddin? .. I'm even intimidated by the new Korg Volca Modular!!
:sadbanana:
I'll stick to drilling holes, cutting metal, and soldering wires. "Stay in my own lane".
Or as Dave Matthews put it .. "even the monkey knows to ~stay in your fuckin tree~".
:hmm:
Rex Coil 7
Re: Patch & Tweak no#4
Post by Rex Coil 7 » Sat Feb 23, 2019 7:14 pm
DaviT wrote:.... i'm still a noob' when it comes to modular.
Well you think of yourself "as a noob" and you're putting out content like this?
Holy crap, you're going to be an amazing modular programmer when you're "experienced" in your own estimation!!
Seriously, have you heard what you're creating? Great stuff!
DaviT wrote: [video][/video]
Yea ... right. :roll:
:hail: :hail: :hail: :hail:
:tu:
DaviT
Post by DaviT » Sun Feb 24, 2019 2:17 am
Thank you for your kind words Rex Coil 7
nidas
Post by nidas » Sun Feb 24, 2019 2:50 pm
good work DaviT and great posts by fellow wigglers..
I only wish you could share the patches or atleast explain them a little for your youtube videos.
I´m getting inspired by the posts above and your videos!
DaviT
Post by DaviT » Sun Feb 24, 2019 2:54 pm
Will do, the problem is that i make the sequence, patch and hit record. Gonna try to remembernidas
Return to “5U Format Modules”
