Can't find the name of SMD caps "case" for assembl
Author Can't find the name of SMD caps "case" for assembl
batchas
I’m blocked at some point cause I don’t see what is to be written for these caps under „case" for a BOM that has to be send to a manufacture for assembly.
In Diptrace it’s written „CPOL-USC“ for all the big caps, in despite of the fact that they don0t have the same size (different values), so I’m hesitating.
I can’t find it in the datasheets (I find the dimensions, but not the „case" reference - nor something lile "CPOL"). First time I use these, cause I always replace them with TH, but this time I’d like to have all on my PCB as SMD as it'll be assembled by machine.
Reference: EEE-FK1E100R
Description: Aluminum Electrolytic Capacitors - SMD Aluminum Electrolytic Capacitors - SMD 10uF 25V
Case: CPOL-USC
Dimensions / Pattern: CAPAE-4.3x4.3h5.4
Datasheet: https://www.mouser.fr/datasheet/2/315/ABA0000C1181-947564.pdf
Reference: EEE-FT1V470AR
Description: Aluminum Electrolytic Capacitors - SMD Aluminum Electrolytic Capacitors - SMD 47uF 35volts 5x5.8mm SMD
Case: CPOL-USC
Dimensions / Pattern: CAPAE-6.6x6.6h5.7
Datasheet: https://www.mouser.fr/datasheet/2/315/ABA0000C1240-1130326.pdf
I dunno if I can simply write for instance: CPOL-USC-4.3 and CPOL-USC-6.6?
mskala
I think this has to be answered by the manufacturer. Only they know what values they're expecting to see in that field.
Alfrede
Hi batchas,
i think C Pol is standing for capacitator polaraized.
As you see here:
https://macrofab.com/blog/the-footprint-files-electrolytic-capacitors/
or https://www.tutorialspoint.com/basic_electronics/basic_electronics_pol arized_capacitors.htm
I found for panasonic smd Polarized
https://industrial.panasonic.com/cdbs/www-data/pdf/RDE0000/ABA0000C118 1.pdf
In this pdf you can see the SizeCode in the Demension Section. And now you know what Size you need and what case for which Capacitator.
I maked in the attached file: (not nice but hopefully understandable)
Boogie
Hi batchas
It's in the datasheet you attached.
batchas
Alfrede wrote:
i think C Pol is standing for capacitator polarized.
Oh! Indeed d'oh!
Okay. Thanks thumbs up
I worried too much then.
I saw these in the datasheets, but I was actually expecting something like what I have for the other components used on the PCB: TO-252-3, 0603, SOT-23-3 and so on. This kind of naming.
batchas
Yeah. I will ask them thumbs up
