paperface/73-75 vs STS
Author paperface/73-75 vs STS
anselmi
I just saw the 73-75 panels and they´re way cheaper than the STS ones, so I started to read about both and the differences between them, but I´m still confused
would you introduce me to the Serge world with a little scheme of the main differences and why such a difference in cost? I´m talking about the 73-75 reissues, that maybe are not at the same level of the originals...I don´t know
thanks!
Triglav
The 73-75 is the first generation of Serge modules, meaning no NTO, DUSG, VCM, VCFQ/S or ResEQ. It's also DIY. (That doesn't mean it's not awesome.)
In contrast, STS is pre-built and has everything but it's by far the priciest of the Serge offerings. Take a look at Random*Source, loudestwarning and elby-designs for more affordable versions of the same modules. (They are all official, licensed circuits by Serge himself)
anselmi
thanks for the info, but I already know this...I´m looking for a more developed answer, like what are the differences infeatures and sound of oscillators, filters and the like between both
I didn´t know this...such a shame...my DIY skills are lame
Anyway, I found what seems to be already assembled panels for "cheap" in Reverb seriously, i just don't get it
yeah, I started there, and they just saw the 73-75 project so I was looking for information...I think I´d have to revisit the R*S option
the bad producer
In general one can talk about 4 'generations' of Serge, the 73-75 set is based on the'first and second generations, these were the first circuits Serge created (between those years, hence the name), for a bit more history have a look at this:
http://www.elby-designs.com/webtek/euro-serge/documentation/book_1.pdf
From the introduction:
This was the guiding principle of the early Serge:
make available electronic functions that are interesting
in themselves, though seemingly "un-musical".
Thus modules like the positive slew, negative slew, peak
and trough, comparators, processors and wave
shapers, etc. came into existence.
The 3rd generation were newer circuits, introduced in 1977. This included the DUSG, TWM etc. Then in 1981 the 4th generation was introduced, including the WAD, QUO, NCOM etc. This is all cribbed from the internet, so may not be super accurate, but AFAIK is correct. The STS line is 4th gen.
The differences are both subjective and objective - for example some prefer the sound of the 73 VCF to the VCFQ, others don't. But one thing is certain, the later VCFQ is a more 'developed' circuit.
papz
The older the revision the better the sound.
That's a basic rule of the musical instruments world and applies to any synth. twisted
chorus7
Having owned both STS and now a 73-75 (which I’m selling unfortunately) I can say the 73-75 is raw sounding... it seems more electric sounding like old 60s 70s sci-fi sounds... but because it’s so stripped down it begs to be experimented on... patching up new ways to make things work results in some amazing sounds... The closest thing I can compare it to is Buchla 100... very percussive and droney...
wavecircle
I think the 73-75 is fairly limited on filters, if any on the DIY system?
The DIY 73-75 doesn't have the amazing flexibility of the SSG, DTG or DUSG, just the positive and negative slews. The SSG and DTG/DUSG are essential modules, so powerful and versatile.
The lack of filters on the DIY system is the kicker for me. I've only had the VQVCF but they all sound amazing in their own way.
dbernhardt58
Shortly after i started a Eurorack system, I started getting some R*S 3U Serge modules, as well as a few Elby 3U Serge modules. The R*S are more modern modules like SSG, DUSG, ResEQ, VCFQ, VCFS, NCOM; while the Elby are the older: 73 EG, Triple Bi-Directional Switch, Slope Detector, ASR. I was a beginner at modular synth (still am, really). Then I decided to add some Loudest Warning format 4U stuff, and also found a 4U COA Sequencer/Programmer panel. Then I added the 73-75 Homebuild (I didn't build it, I found someone to do that for me).
Learning Serge takes a good bit of effort. You need to read the old manuals, search out any video demos you can find, analyze Eurorack patch tutorials to see how they apply to the Serge, maybe take some Skype/Facetime lessons if you feel like it, and more. The good news is there are a good number of videos: Doug Lynner, Todd Barton, Batchas, etc.
I documented my journey starting at the beginning fairly thoroughly here on MW. Just do a search for my posts - most are video demos with patch notes - if you want to see the 73-75 system. I don't think it's limiting, I think it is liberating to have that set of modules in two panels. Take what you hear online with a grain of salt, because sound quality of the recording and videos varies from great to barely OK.
I think it's like any modular journey: you benefit from doing a lot of research first, and adding modules (or panels, if you go that route) slowly. Not that I added slowly, of course, which I only regret because I got a little overwhelmed. That's why I started taking lessons, and it's helped.
Also, what is your take on electronic music/sound/composition? For me, learning about the hardware and playing with it, and listening back is half the effort; the rest is trying to understand the broader historical context, and what is happening now. I have been reading "Composing Electronic Music, A New Aesthetic" by Curtis Roads, which has lots of sound examples you can listen to on-line. The range of expression will blow your mind, if you want to expand your listening experience (of course the electronic music tools used on many of these examples goes far beyond any set of Serge modules). I also listen as much as I can to podcasts to hear curated electronic music.
So you get and idea and try to patch it up; rinse, repeat. I think any Serge generation of modules and any format will be bring a super fun and musical experience. If that aligns with your personal goals, go for it.
Gandalf
I suggest you recheck the EuroSerge catalogue from ELBY Designs. Their range covers just about everything from the 1st Series to the 4th Series so with the exceptions of the PCO, NTO and later filters, you will find pretty much all of the Serge stuff there and that includes the SSG, USG, ResEQ...
dbernhardt58
I was referring to the Elby modules that I have added to my modular; not to the range of Elby modules that are available. I am quite aware that Elby features a wide range of Serge modules, and is constantly expanding that range. If I was independently wealthy I assure you I would have one or two of each.
Anybody who gives two shits about any of this goes to everybody's website and figures out what's available. Sorry about that.
aethyr
RS is almost as expensive as STS woah
syncretism
It's not exactly apples to apples because you can buy modules from R*S in addition to full panels (and STS M-CLass was discontinued, IIRC), but a new La Bestia panel comes is well below the price of a new Animal. New R*S panels are about what you would pay for second-hand STS.
That said, all Serge format (maybe all 4u?) stuff is expensive. I'm not saying it's overpriced; it just costs a lot, compared to 5u and Euro. I can't speak to the economics of that.
Prunesquallor
A built R*S panel works out at 300-350 Euros per module, which is in the ballpark of any premium module. It just seems steep because you're buying 7 or 8 together in one panel. If you were to buy the same number of Verbos or Cwejman modules the cost would be significantly more.
Regarding Serge generations, I think Ken Stone's CGS stuff (as built by Loudest Warning or Elby) is sufficiently different from STS to call it generation 4.5. R*S then would be generation 5. But this does not mean that one is superior to the other, just different.
tmeade
M-modules are discontinued? That is news to me. When did that happen?
syncretism
I think I read that a couple years ago; my sincere apologies if I'm misinformed.
peeninety
Does anybody know if the pre-built 73-75 panels are available yet?
sanders
This quote is worthy of framing
thetwlo
true, but RS has been re-designed and upgraded, better op amps. vap.. an' shit.
Still that doesn't mean we might prefer the sound of the 73-75.
I can't tell what you even are buying at their site 73-75. Two options, same price. no clue what's included.
cygmu
There aren't two options, only one. When you have just one product I guess your "new products" and your "popular products" tend to be the same thing... so it gets listed twice thanks to lazy deployment of a web store template I suppose.
There's a little more info if you click through:
Package contains two front panels and three circuit boards (2x main board and 1x PSU).
drift
Rex has new creature v2 & audio interface M-class panels with boat and power supply for sale on Reverb.
