New SSL VCO ???
dslocum
darwin's nemesis
New SSL VCO ???
Post by dslocum » Mon Mar 25, 2019 8:39 am
Guys,
"IF" I were to do an updated 1 MU VCO, it would be based on the CEM3340. I like the existing feature set on the 1200, so I'm inclined to stick to it unless there are other suggestions.
Do you think a rotary octave range switch or continuous coarse pot would be preferred. The range switch would add to the price.
Another thought would be a coarse pot but add a center-off toggle switch for +/- 1 octave.
Another concern is the hard sync. It would be different sounding from a saw core. Would that bother anyone?
- So here we go. I can't wait for the comments!
Doug Slocum
Synthetic Sound Labs
www.steamsynth.com
"I guess all the Forest Mims Radio Shack books I read finally paid off!"
"I ordered twice as many _______ as I thought I'd need, only to find out that I'm still less than half way to having enough."
"...this whole thing was started by a dream and a mouse." - Walt Disney
"Flatulence sounds aren't just for brass and reed instruments anymore, thanks in large part to Dr Moog." - Ockeghem
Post by JohnLRice » Mon Mar 25, 2019 11:21 am
How about having the range control be radically different? I present you the SSL 1124 BinRan VCO with Binary Range control. :eek: 8-) The three switches add 1, 2, or 4 octaves so available ranges are:
64, 32, 16, 8, 4, 2, 1, and all switches on/up is the "Wide or Coarse" range where the Fine tune pot becomes a Coarse tune pot. The jacks accept gate inputs so range can be controlled by sequencers or LFOs etc. If a switch is already 'on' a gate could either do nothing OR it could remove that increment, maybe make that behavior jumper selectable, Normal - only turn on, Inverse - set range opposite of switch position?
I think it would be fun, usuful and stand out in the VCO crowd. :spin: :nod:
Dave Peck
Post by Dave Peck » Mon Mar 25, 2019 2:36 pm
You could do that octave switching with just two toggle switches instead of three. The first switch adds or subtracts one octave. The second switch adds or subtracts two octaves. So you get -3, -2,-1, 'off', +1, +2, +3. The '-3' and '+3' are achieved by setting both switches up or both switches down.
Post by JohnLRice » Mon Mar 25, 2019 2:44 pm
Dave Peck wrote:You could do that octave switching with just two toggle switches instead of three. The first switch adds or subtracts one octave. The second switch adds or subtracts two octaves. So you get -3, -2,-1, 'off', +1, +2, +3. The '-3' and '+3' are achieved by setting both switches up or both switches down.
Good idea! :tu: Although . . . :hmm: . . . I suppose the wide/coarse position would be both switches center off but the gate control wouldn't be as easy to patch because you'd need some sort of bi-polar gate source . . .cool when using LFOs but not easy when using gates from sequencers.
Dave Peck
Post by Dave Peck » Mon Mar 25, 2019 2:47 pm
Also, have you considered changing the pulse width control from a three position toggle to a variable pot? (it would have a small knob). I really like the sound of a pulse wave that is juuuust slightly away from a 50% square wave - sounds massive! Likewise a pulse with a similar setting and just a small amount of PWM so it goes from maybe 49% to maybe 40%, staying pretty 'wide' while never becoming a 50% square wave.
But on the current design, you would have to connect some kind of small DC offset source to the PWM input to get the first effect, and you would need a DC-coupled mixer module to combine a DC offset and an LFO to get the second effect. Having a variable PW knob would make it simpler to get these kinds of effects.
ericD13
Post by ericD13 » Mon Mar 25, 2019 3:04 pm
JohnLRice wrote:How about having the range control be radically different? I present you the SSL 1124 BinRan VCO with Binary Range control. :eek: 8-) The three switches add 1, 2, or 4 octaves so available ranges are:
You're missing 128 = 2^(1+2+4)
"Unfortunately it took me forty years to conclude that nothing is possible outside DoReMi."
P. Schaeffer
Lots of 5U modules to sell in europe :
https://www.muffwiggler.com/forum/viewt ... p?t=219781
Post by JohnLRice » Mon Mar 25, 2019 3:07 pm
:hmm: :despair:
hsosdrum
Post by hsosdrum » Wed Mar 27, 2019 4:00 am
Although I'd prefer a multiple octave switch in place of the coarse tuning control, adding a +/– one octave switch to the existing coarse pot would be a good compromise for those who also want to be able to manually sweep the oscillator from D.C. to light.
Providing it sounded as sweet as the 1200 (especially the square wave), such a device would sorely tempt me to replace my 6 remaining Q106As.
kindredlost
5U skiff friendly
Post by kindredlost » Wed Mar 27, 2019 6:44 am
I’d prefer a toggle switch over a rotary as well. The rotary switches on my older Q106’s are all scratchy by now (10 years old). I have to “work “ them a bit for them to settle down. A toggle is a more stable solution as long as I can read the octave position easily.
josaka
Post by josaka » Wed Mar 27, 2019 7:55 am
A kobol sounding osc with a 921B feature set would be the ultimate for me.. :)
wsy
Post by wsy » Fri Mar 29, 2019 7:41 am
Keep the coarse "DC to Daylight" pot. It's darn handy.
Makes it easy to explore going from a slow LFO to near ultrasonic.
Much creative potential.
Octave switches can be handy (+-1, +-2, +-4) but please keep the knob!
- Bill
"Life is short. But we can always buy longer patch cords" - Savage
Post by MindMachine » Sat Mar 30, 2019 12:04 am
^ That deal right there.
BudgetInfinity
Is anyone else making single wide VCO's in 5U MU?
Post by BudgetInfinity » Wed Jun 26, 2019 5:48 pm
I've been looking around and can't find any. SSL sold out of their 1U VCO, and I see the 2U double VCO from Moon is sold out too.
I guess there's always eurorack... :despair:
Dave Peck
Re: Is anyone else making single wide VCO's in 5U MU?
Post by Dave Peck » Wed Jun 26, 2019 6:24 pm
BudgetInfinity wrote:Is anyone else making single wide VCO's in 5U MU?
A few, like Krisp1/Oakley. But not many out there other than these two.
Post by JohnLRice » Wed Jun 26, 2019 6:39 pm
:stg:
Flareless
Post by Flareless » Thu Jun 27, 2019 8:48 pm
Lower West Side Studio offers a 1U version of the Music From Outer Space Voltage Controlled Oscillator
Sorry for the hijack Doug
Rich
What can this strange device be? When I touch it, it gives forth a sound - Neil Peart
pj_composer
Post by pj_composer » Fri Jun 28, 2019 3:19 am
Post by MindMachine » Fri Jun 28, 2019 8:43 pm
JohnLRice wrote::stg:
Very interesting. That answers a question I was just asking myself minutes ago as I sat in front of my MU. I have 'X' empty spaces and this may just buy me another iota of 'X'.
FS: A-140-2 Dual VC ADSR, Erica VCA 2, SP-555 Sampler and more - CHEAP!!!
viewtopic.php?t=222871&highlight=
WTB: Kurzweil Rumour (or trade for Mangler)
dslocum
darwin's nemesis
Post by dslocum » Wed Jul 10, 2019 11:20 am
Good suggestions all!
I'm working on a design that addresses just about EVERYONE here. If it works, you can call me :
:hihi: :goo: :sb:
(If it doesn't work, you'll never know! He he :hyper: )
Doug Slocum
www.steamsynth.com
Xero
Post by Xero » Wed Jul 10, 2019 12:16 pm
ooh tempting.
I already have one ssl vco, maybe I need another????? I need more cabinet space lmfao
Rex Coil 7
Post by Rex Coil 7 » Sat Jul 13, 2019 2:04 am
Xero wrote:ooh tempting ... I need more cabinet space lmfao
Yea, ain't that a bitch! There is so much great 5U stuff I'd like to add to my current 5U stuff. MOAR 5IVE YOO STUFFS!!!!
:redneck:
:yay: :party:
dslocum
darwin's nemesis
Post by dslocum » Sat Jul 13, 2019 10:46 am
OK, here's the idea. :bop: :hide:
Doug Slocum
www.steamsynth.com
josaka
Post by josaka » Sat Jul 13, 2019 2:26 pm
looks good.. dont get the sine output though.. its the wave that gets used the least in my studio.. as an lfo occasionally.. sure there are other more interesting options.. saw? put the sine in with the selectable others ?
square and saw outs are most used here..
hsosdrum
Post by hsosdrum » Sat Jul 13, 2019 4:25 pm
Looks great, Doug! Love the addition of the PWM control and the Octave/Vernier options for the Coarse control. (My secret identity as a technical writer forces me to point out that the illustration omits the "n" from "Vernier".)
Would it go slow enough for LFO duties?
dslocum
darwin's nemesis
Post by dslocum » Sat Jul 13, 2019 4:46 pm
hsosdrum wrote:Looks great, Doug! Love the addition of the PWM control and the Octave/Vernier options for the Coarse control. (My secret identity as a technical writer forces me to point out that the illustration omits the "n" from "Vernier".)
Doh! Fixed on my master. Thanks for catching that.
Yes, slow enough for Government work (slow vibratos, swells, etc.), but maybe not as much as a serious "dedicated" LFO which can go into the minutes or hours! :-)
Doug Slocum
www.steamsynth.com
Return to “5U Format Modules”
