Buchla MARF alternative in MU ?
nidas
Post by nidas » Sun Mar 31, 2019 7:42 am
Are there any kind of MARF in MU land?
Seems like an extremely well thought out way to do performance and play with quite simple sequencer CV.. It has 4 inputs and seems to have 2 different output at the same time.. Switches for controlling octave and timing changes and so on..
Yes I saw Suzanne Ciani perform a couple of days ago and really liked what she did with the MARF during that performance.
sduck
experimental use of gravity
Post by sduck » Sun Mar 31, 2019 8:59 pm
Adapting the currently available MARF pcbs to 5U would be rather unwieldy - it would be super wide. Someone would really want to redo the design specifically with 5U in mind.
levelhead3
Post by levelhead3 » Sun Mar 31, 2019 10:56 pm
Actually not all that bad, at least physically. 4u in Buchla = 8u in MU, so no wider than a Q119 or 960 sequencer.
nidas
Post by nidas » Mon Apr 01, 2019 2:38 am
sduck wrote:Adapting the currently available MARF pcbs to 5U would be rather unwieldy - it would be super wide. Someone would really want to redo the design specifically with 5U in mind.
yes that ofcourse would be fantastic but are there similar module / modules that could do the same as a MARF..
ArguZ
Post by ArguZ » Mon Apr 01, 2019 9:13 am
Remember the MARF is a function generator and not a sequencer .
Unless someone changes the firmware and makes the time components follow rhythmic patters it disrupts anything that follows a static BPM.
When we need is a way to set the time sliders to overwrite the next steps, not add time in between them.
Post by JohnLRice » Mon Apr 01, 2019 3:41 pm
I've never owned a MARF and haven't even studied what it does exactly but maybe take a look at the Encore Electronics UEG? (Universal Event Generator) It's obviously much simpler then a MARF but it does have a timing pot for each of the 8 steps. It's no longer available in MU format as far as I know but the MOTM format ones are still available and it would be relatively easy to repanel one into a MU panel. :hmm: Actually, putting two UEGs plus another module or two behind a 4 to 6 MU panel might give you a very powerful and interesting pseudo MARF module?! :hyper: :tu:
http://www.encoreelectronics.com/cont_ueg1.html
nidas
Post by nidas » Tue Apr 09, 2019 4:09 am
Thanks JohnLRice - I have totally missed this module.. Its not a Marf by far but coul be fun in MU land..
jvt
Post by jvt » Sat Jun 29, 2019 10:15 am
Another approach (again, not actually a MARF) is to use any multi-row sequencer and a voltage controlled clock/LFO. Clock the sequencer with the clock source and route one of the sequencer rows to modulate the clock/LFO speed. A Serge slope type circuit can be added to spice up the CV output. There's also no reason the MARF couldn't be emulated digitally. Would make for a much smaller and cheaper module. No idea why no one has done this.
Return to “5U Format Modules”
