SSL-4000 DIY compressor issue
Author SSL-4000 DIY compressor issue
Troubleshooter
Hi all,
Build myself one of those Gyraff Audio GSSL comps.
Everyhging works within a certain range of the settings but the unit behaves bad @ higher copression.
When I turn the threshold down slowly and I receive more and more compression @ a certain level (around 10db) of compression the needle jumps all the way to maximum compression and the unit goes silent for a brief moment. Then the sound returns @ the speed set by the release.
Every control element on the panel works but once I hit a certain amount of compression the thing goes TILT.
On a typical drum loop this happens every 2 snaredrums or so.
Any ideas?
Thanks in advance.
Trachea
Perhaps the GSSL threads over at GroupDIY could be helpful, they have tons of info.
https://groupdiy.com/index.php?board=27.0
AonFLuX
Do you have any add-ons installed? Turbo-board?
Troubleshooter
No, I have the Turbo switch ready in my frontpanel but built the basic version for now.
AonFLuX
Ok, cuz I think I might experience the same when engaging the Turbo-mod. I will open it up soon and see if I can find something. So, no hints for the trouble now I'm afraid.
