Wiring Iec320 C14 Switch and Meanwell.
Author Wiring Iec320 C14 Switch and Meanwell.
n167tx
Is this image from Befacos (Power_Supply_Connection_Assembly_Manual.pdf)
wrong?
The fused HOT from the switch is connected to Neutral of the Meanwell ?
Here is the full Manual:
https://www.befaco.org/docs/Power%20bus/Power_Supply_Connection_Assemb ly_Manual.pdf
Graham Hinton
wrong?
Yes this is wrong and there are three other mistakes. If you wanted to prove that you were an incompetent clown selling dangerous kits you couldn't really do better than this. Some others have tried, but this one is ahead by miles.
n167tx
Sorry, i did not meant to offend anyone. Was just triple checking everything
What are the other ones?
Graham Hinton
It's not you that's causing offence, it's Befaco.
You are quite right to question this.
Exposed live mains wiring on inlet. That type should have a "boot" cover.
Wrong wiring colours.
No grounding of the power distribution 0V. The PSU connection is only a frame ground.
Connecting two Coms together at the PSU does nothing. Two wires joined at the distribution would be better.
KittenVillage
You may want to read through this thread for some wiring tips. Be aware of the changing wiring diagram.
I'm a newbie too, but that other thread covers a lot of bases when it comes to wiring up those meanwell power supplies.
