Guitar pedal send/return pedal thing
Author Guitar pedal send/return pedal thing
submute
I feel like what would be awesome on my pedal board is a pedal that has a few send/returns so i can route stuff around live without re-plugging/configuring the pedals themselves... Is there such a thing?
pricklyrobot
There’s this:
https://www.boredbrainmusic.com/product/patchulator-8000/
Idunno
Do you mean reroute pedal order on the pedalboard, or reroute to external devices like synths?
I'm sure there are plenty of solutions to either, but it'd help to know what you want to achieve.
Zube
Boss LS-2 is what I use live. I also have a little DIY patchbay that I use with the LS-2 in the studio to quickly reroute signals.
submute
I want to re-route pedals on the board, that's all. That Patchulator 8000 seems like a perfect fit. Any other options?
Idunno
Yeah, that little patchbay is quite nifty. Hadn't seen that before. Although having all those patch cords sticking up in the middle of the pedalboard ain't too smart.
Loop switchers can be anything from simple passive boxes with one or two loops &/or order switching to more sophisticated boxes (Radial do a range of "Bigshot" looper and switcher stompboxes) to more expensive stuff like the Boss MS-3 Multi Effects Switcher, Boss ES8 Effects Switching System, Pigtronix Keymaster (out of production now, but secondhand???).
There's loads of FX loop switcher boxes available, but less boxes that do FX order switching. It's easy enough to build though. If you know someone who knows how to use a soldering iron perhaps they could make you something. It's only (foot)switches and Jack sockets at it's most basic. There's a wiring diagram at the bottom of this page: http://beavisaudio.com/projects/looperswitcher/
filtermod
Is this what you're looking for? https://www.earthquakerdevices.com/swiss-things
If you want to do more specific routing there's this. https://www.rjmmusic.com/effect-gizmo/
Pedalboard wise you could use one of these. https://www.ehx.com/products/super-switcher
Or these https://www.boss.info/us/products/es-8/
Lots of other options too.
pricklyrobot
Haven’t done it yet, but I’ve pondered building a pedal board with a regular rack patchbay at the top. Drill holes and connect all your pedals to the back of the patchbay. Then just rearrange order, feedback patch, etc. at the front (I’d probably assign a cable color to each pedal, to minimize visual confusion).
All your wire spaghetti would be at top of the pedalboard so you could still tweak knobs and whatnot.
pricklyrobot
Also, not what you were asking for but another cool little tool to get more out of your existing pedals, if you DIY at all:
http://jmkpcbs.com/product/paralyzer/
Zube
Skb made a pedal board for a bit that is exactly what you're describing. It was pretty cool and tidy.
Rex Coil 7
The Boss LS-2 not only does a GREAT job of send/return (2ch worth) but it's also a great clean booster. It can add up to 20db of clean gain to each of the two separate s/r loops. I've owned two of the LS-2 units for over ten years now ... very well spent $120.00.
smetak
Earthquaker recently released this:
gearhead61
A bit -
But VERY cool!!
http://www.soundsculpture.com/switchblade8f
mrbloor
VFE Klein Bottle.
Video[/video]
Moerdertheke
As an alternative for the Patchulator, I use angled jack adapters on my board, so it's just a matter of repatching cables if I want to change the routing. It's finnicky, ugly and needs more space, yes, but with a bit of pedal tetris you can get a really nice modular setup done. The adapters becomes quite pricy with more pedals, though.
Regarding patchbays, you can also try to get a passive ART TPatch, remove the casing and tape the individual patch groups to the side of you pedal board. All the patchable ins/outs are connected from the bottom and you can easily patch the connections from the top. Worked quite well for me to save space.
A third option is to buy one of those super slim 4ms Eurorack pods with and slam a matrix mixer in. Or just passive multiples/jack converters in a DIY case - that'd get you closer to the Patchulator. It's definitely a pricier version given that you'll need both jack converters AND matching modules. Or cables that go from flat jack to patchable minijack.
p.j.
I got one of these a couple months ago and it is tremendously versatile. Awesome product. Right now I have a guitar synth in one loop and regular guitar in the other. Boss Line Selector info
dkcg
pricklyrobot wrote:
There’s this:
I just got one of these things. One thing I was curious about was if the routing went all the way through the TRS jacks so unbalanced stereo could be used.
Sure enough, I can now switch the order of my Meris Mercury, Ottobit, and Polymoon all in stereo.
So if anyone wants easy stereo pedal order switching in stereo or mono, this can do it. Might not work so great switching order on a mono pedal with a stereo pedal depending on the mono pedal.
Found this out after I ordered a DIY effects order switcher kit, but that only does two mono signals.
The jacks on top might make it not so great for on the ground boards, but for wigglers, this thing is pretty cool.
p.j.
The LS-2 is actually really configurable and very inexpensive. I use it for switching between regular guitar and guitar synth. Works like a charm.
Severed head
I wouldn't buy anything from earthquakes devices
smetak
And why would that be?
Slothrop
Can the LS2 do ordering as well as just switching?
And can you re-patch the Patchulator live without getting plugging / unplugging noise? It does look rather cool...
I've got a Klein Bottle, FWIW. I absolutely love it, but I'm using it for live tweaking in a sort of pedalboard-as-mini-modular setup rather than just for swapping things around - re-ordering effects involves a bit of hand-and-knees knob twiddling rather than a straight footswitch.
Big pedal routers like the Boss ES5 seem to be able to do this sort of stuff, of course, but they're also fairly spendy and possibly overkill depending on what you want them for...
