Cable for old oscilloscope
Author Cable for old oscilloscope
msegarra
I’m trying to use an old oscilloscope for my eurorack and was hoping to use a cable that was less rigged would this work?
Cable
msegarra
Oops sorry i suck at posting lol this https://bolioptics.com/bnc-to-av-cable-1-5-meter-5-ft/
guest
probably, although its hard to say for sure, as there are 4 contacts on the 1/8" plug side and the bnc side only has 2. there isnt a description of which ones go where.
Mungo
good explanation.
The easiest way to get a suitable cable is to make one. BNC connectors need a crimp tool, so buy a premade cable and cut it in half. RG-174 and RG-179 are thin and flexible like patch cables. 3.5mm connectors can be easily attached with a soldering iron.
sduck
Regular scope probes can attach easily to 3.5 plugs, then just plug the other end into whatever.
Revok
An off the shelf solution is to use a 3.5 to rca cable with an rca to bnc adapter on the scope.
selfdestroyer
I picked up these and they work great with my scope
https://erthenvar.myshopify.com/collections/3-5mm-cables/products/3-5m m-to-bnc
MikeDB
Or put one of these on the end of a BNC to BNC cable
https://www.amazon.co.uk/Gold-Plated-Socket-3-5mm-Adaptor/dp/B008F9CB6 4
