How to create 12V power from the 15V source in an MU rig?
Author How to create 12V power from the 15V source in an MU rig?
Dave Peck
I'm going to re-panel a Rossum Morpheus filter Euro module and install it in my MU/5U modular. I'm checking with the manufacturer to see if the module can be powered from the +15/-15V DC power system that is already in my modular, but in case it cannot, I'll need to find a simple cheap way to provide the required +12/-12V DC.
I could buy a dedicated 12V power supply like this:
https://www.mouser.com/ProductDetail/MEAN-WELL/PD-2512?qs=V9a8iPeg90zL 57YT5CaFMw%3D%3D
... and use a simple modified ribbon cable to connect it to the module, but I'm wondering if folks here have already dealt with this and come up with a better way to provide 12V power for just one or two Euro modules in a MU / 15V system?
Does someone offer a cheap & simple 15VDC to 12VDC regulator board for a couple of bucks? I would prefer not to MAKE a circuit, I would rather just throw a few bucks at the problem.
diophantine
Yup! https://oshpark.com/shared_projects/IMyjiSay
I use one to power a row of Euro (Klee + two Livewire modules) in my Frac system.
I should have a couple extra boards; if I find one tonight, it's yours - I'll PM you.
dslocum
Define "A couple of bucks". Miley Cyrus
A couple years ago I made myself a MU to Euro power board that I could use on my test bench setup. It has 7812 / 7912 regulators and a few DOTCOM and Euro16 connectors. Working well for me. Let me know if you'd like a bare board.
Otherwise, I'd be open to designing / offering something for the Muffs community as a group buy.
dslocum
Here's a quick photo:
sduck
I'm glad Doug's solution and that oshpark thing exist now! Back a few years ago when I was doing a lot of euro conversions those didn't exist, and I would build up a converter on protoboard for each. It's not a big deal to do so, but not something you'd bother with if there was a readily available solution.
Dave Peck
update - member diophantine is sending a board to me. Thanks!! nanners
Rex Coil 7
cool
Synthbuilder
dslocum wrote:
I like that you've used a vintage 1976 Fairchild 7912 to ensure your Euro module doesn't sound too modern. hihi
Rex Coil 7
cool
josaka
think a board like this would have a lot of takers.. more euro ports though..
beautyofdecay_
I have been using the Trace Power TMR 3-1222 DC-DC converter with succes.
Input 9-18V DC, output +12V and -12V DC @125mA max.
https://power.sager.com/tmr3-1222-3982838.html
Just 1 component...
Just make sure the DC-DC converter's max output current is high enough for your application.
dslocum
Ha... Yeah I wasn't able to get a vacuum tube regulator in the correct values! hihi
Synthbuilder wrote:
megaohm
All of these reg boards omit the diodes.
Not sure if that is a good idea. Some data sheets discuss this and others don't.
Because of that I have many 78xx data sheets from a variety of manufacturers.
All together they form a clear picture?
The LM340/LM78xx Series , National Semiconductor July 2006 page 11 does the best job discussing these diodes.
They are for protection in case of a fault.
From what I understand, there should be a diode (1N400x) connected anode to reg output and cathode to reg input. This prevents the regulator's output from being higher than the input.
A second diode should be connected cathode to reg output, anode to 0V.
This will shunt negative voltages to ground.
I found a link to that same datasheet except by TI (page 13 and 16).
http://www.ti.com/lit/ds/symlink/lm340.pdf
megaohm
NOTE!!!!!!!!!!!!!!!!!!!
For the negative regulator you need to reverse the diode connections I described above.
Dave Peck
Just 1 component...
Those types of DC-DC converter modules would be a good choice for most euro modules and that's what I had originally thought of using. Just stick one on the back side of each euro module to convert power for each module separately.
Unfortunately the Morpheus draws 135 ma @ +12V. And there aren't many of these converter modules that offer that much 12V current from a 15V source. And those that do cost more than a small AC-DC power supply that can power several modules.
But if I had been doing this for something other than a Morpheus this is probably what I would have used.
dslocum
The general idea that I come away from on this is that the INPUT cap on the 78xx regulator must be significantly greater than the output cap.
That way, when the system powers down, there will always (hopefully) be a more positive voltage on the INPUT side than the load (output) side.
The diode across the input to output in these examples helps "dump" the charge back to the input, rather than thru the 78xx regulator, which wasn't designed for this sort of thing.
megaohm
That is smart!
Didn't think of that.
But the diode may still be a good idea in this app because we can't predict with certainty what capacitance the output side will see since it depends on cap choice used in the euro module.
But in circuits that use regs for ref voltages that idea should work perfectly.
Should save a diode and the pcb space it takes up.
Thanks for sharing that/pointing that out!
Synthbuilder
I have found some benefit in using 1N5819 Schottky diodes as the shunt reverse polarity protection diodes. Some devices, infamously with the V2164 but less well known are op-amps like the TI version of the LT1013, will go into serious meltdown without those diodes if one of the power rails goes missing.
The ones across the regulators can be 1N400X still.
Tony
dslocum
Guys,
Hope this helps...
I have two of these PCBs. I'll send them FREE if you pay for postage. PM for details.
Dave Peck
dslocum wrote:
Guys,
Hope this helps...
Hi Doug, If this offer was pertaining to me, thanks very much! But I have already received the 'Oshpark' 15V to 12V DC/DC regulator board that was mentioned earlier in the thread, sent to me along with some of the parts from wiggler Diophantine. The rest of the parts are already ordered from Mouser and will be here Monday. Looks like I'm set but thank you for the offer!
dslocum
Dave Peck wrote:
dslocum wrote:
Guys,
Hope this helps...
Dave / All,
It was a general offering for any and all Muffs. cool
Dave Peck
Update - 12V power adapter is completed and is up and running, the Morpheus Module tests OK in the system.
Now I just need to order the new MU adapter panel from Front Panel Express and install it. I just heard back from the guys at Rossum with some instructions for properly wiring the connectors & grounding the module.
Dave Peck
Update - it's finished! Works great. I love this filter!
