Korg SDD 1000 faulty
Author Korg SDD 1000 faulty
Saltech
Greetings, I'm looking for any tips for repairing a faulty SDD1000, including recommendations of good forums for such advice, if here is inappropriate.
The unit powers up but appears to be stuck in bypass mode - only the clean input signal is being output from all 3 outputs, no effects / wet signal. There is a bypass push switch and its LED lights up when this is engaged, and there is an output mixer section with "Direct" and "Effect" level pots - but the output remains the same whatever the settings. Inside the unit everything is clean with no sign of burns or damage. Any ideas?
