Shot Es-3 mk4 ?
Author Shot Es-3 mk4 ?
Mdashdotdashn
I've just aquired a ES-3/ES-6 Combo but I don't seem to be able to get the ES-3 to lighten up. I'm trying to drive it through a Babyface pro but no led rings shows up and the main led stays dark.
The interface is set to 44.1K, digital outputs to ADAT and I've checked the cable by looping it back to the interface's input which then reports incoming ADAT signal.
What can I do to troubleshoot ?
Thanks in advance,
Marc
Have you tried just the ES-3 without the ES-6?
Mdashdotdashn
Yes I did. Same thing.
Usually in these situations the problem is that the optical cable is carrying SPDIF, not ADAT, but since you say you've checked that, I'm at a loss.
Are these modules new?
Mdashdotdashn
Yes, I received them from Thomann like 2 days ago
Just to be absolutely sure can I see a screenshot of your RME settings window?
Mdashdotdashn
Looks OK.
Assuming you've connected it to power correctly, it's looking like a dud, which is disappointing. Back to Thomann I guess.
