Synthronics - Modern PSUs for classic vintage synths
Author Synthronics - Modern PSUs for classic vintage synths
polysixer
Just a heads up, Andrej from Synthronics is releasing a bunch of custom replacement PSUs for classic vintage synthesizers and I have to say I'm impressed. Just installed my replacement Juno-6 PSU and on top of being smaller and lighter than the original it seems to have better groundings and isolation, as it's improved a ton of the high pitched noise and DCO leaking into the jacks board, so typical in the Juno-6 and 60. It's a switched solution but with linear regulators, with excellent measurements and low noise. It's also very nicely built, with isolators included and a lot of attention to detail, I highly recommend it.
Link to Juno-6/60 PSU: https://synthronics.de/roland-ju6-60-psu-new/
Korg Mono/Poly PSU: https://synthronics.de/korg-monopoly-psu-replacement/
The best news is that more models are coming, with Jupiter-8 and Prophet VS PSUs dropping very soon. Andrej is also open to suggestions for what PSUs you'd prefer to see. You can contact him on Facebook directly here: https://www.facebook.com/profile.php?id=100006878447478 for requirements, suggestions and orders (don't forget to mention autoy sent you).
tron23
Interesting information, thanks for sharing. Guinness ftw!
polysixer
Prophet VS PSU now available!
https://synthronics.de/sci-sequential-circuits-prophet-vs-power-supply  /
polysixer
Roland Jupiter-8 replacement PSU is ready: https://synthronics.de/roland-jupiter-8-new-psu/?fbclid=IwAR1apRcq-64s 66E3edaD9695AoyU5g_iVKpZuW1_UutQqMmNpEmB7oTcIZ0
No overheat
Efficiency around 75% = less heat inside the synthesizer
Noise free
Precise Over Voltage and Over Current Module that monitors possible fault conditions
polysixer
Polysix PSU replacement now available, much more efficient and less heat: https://synthronics.de/korg-polysix-psu-replacement/
