[Now available] New C111 Multimode Contour Generator
MUFF WIGGLER Forum Index -> 5U Format Modules Goto page 1, 2  Next [all]
Author [Now available] New C111 Multimode Contour Generator
Thalassa
Happy to show the the next Corsynth module, the C111 Multimode Contour Generator. It's a quad analogue envelope generator and modulation source. The module is composed by four identical envelopes ( AD or ASR ) that can be combined by pairs to create envelope shapes that are not possible using a regular envelope generator. Up to six different envelopes are available at the same time. Also each envelope is loopable.
Finally I have time to create a technical demo for the module. I hope that it helps to have a better understanding of this module smile
The module is now available, more info here : corsynth.com
BTW the user manual is already available to download and it has a lot of information and graphics about the different envelope modes. smile
First basic demo
Updated 7th of November
Finally I've had time to create a technical demo for the module. I hope that it helps to have a better understanding of this module smile
josaka
very nice Pablo.. an east/west chaos machine.
Thalassa
Thanks smile
Very cool design! SlayerBadger! It would be fun to patch it into a quantizer, and/or cross patch it into itself! hyper
I know it's probably too late for any design changes . . . (hides) . .but I was thinking it would be nice if there was a manual buttons to fire a one shot so the module could be "played" by hand?? Maybe the LEDs could be momentary LED push-buttons or maybe the Loop toggle switch could be a center off with momentary down positions? hmmm.....
coyoteous
I'm out... no ADD or ADHD.
(kidding... looks great!)
fac
You can obtain an ADHD by feeding back one of the outputs into the input of the opposite side and viceversa. Should be pretty obvious just by looking at the panel. razz
Any estimated price? A couple days ago I was patching my synth and noted a certain lack of envelopes. I do seem to have enough VCAs, though.
levelhead3
stop. making. perfect. modules.
this will indeed fill a noted niche quite handily. Chugging Beers
Thalassa
Thanks John oops . During the design phase I thought about it but the panel was already too crowded. At this moment is not possible to make any changes, PCBs and panels are already manufactured. Anyway in AD mode you can use the loop switch to trigger the envelope. If the envelope is not too fast, turn on and off the loop mode and the envelope will make just a cycle.
Actually an ADD is also possible using the A+B or C+D ouputs. hihi hihi
Set both envelopes to AD mode. Same attack in both envelopes and one decay really fast and the other long. Balance knob in middle position smile
It's not set yet , but it will be something around 250-270€ + VAT for EU residents. If you have two sequenced voices that uses 4 AD or ASR envelopes even 4 of the cheapest envelopes in MU will be more expensive and they will take 4 spaces. Mr. Green
Thank you oops oops
coyoteous
fac/Thalassa: Just my luck you can... additional spoilage to my bad joke.
When I looked at the graphs the first thing I thought was "attention-deficit disorder," then I got distracted, went for a run, took some Adderall, remembered about the graphs and thought "attention-deficit/hyperactivity disorder."
(I'm borderline... yeah, still at least a little inappropriate)
thumbs up Seems like you've got it covered. cool And someone could make or buy one or more off those 1/4" button plugs with a battery inside for on-module gating if needed?
https://www.synthesizers.com/vplug.html
fac
Actually, I often have several percussive sounds going on simultaneously, so 4 AD envelopes (or 2 AD plus 1 ADSR) in a single 2-space module are perfect for me.
KSS
Nice looking module!
Using the existing loop toggle switch position, and changing to an (on)-off-on type will let you have what JLR requested. Can probably even kludge it in, and will be easy to do in the next rev.
Up for loop. Middle native off is off. Down is momentary loop, taking advantage of what you described, but making it easier to perform. Using a red vinyl toggle cover or MOTM style bat handle makes this feel better, but plain bat handles work too.
KSS
Isn't an ADSR really already an ADHD? Mr. Green Guinness ftw!
Thalassa
As a matter of fact I tend to use much more AD and ASR envelopes than ADSR.
Yes that could make it. Connecting the momentary leg of the switch to a voltage source will make a nice gate smile . Maybe in a future MKII version.
ba1
This looks great Pablo!
Count me in for one of these.
Thalassa
Thanks smile
Thalassa
ba1
How soon until these are available at Noisebug?
Thalassa
At least two three weeks
Thalassa
The C111 is on its way to Noisebug. By the end of next week they should have it in stock.
ba1
Awesome! Thanks for the update.
Thalassa
First basic demo. Nothing fancy , just the module controlling two synth voices. smile Now I have to do a more complete one showing all the features of the module Mr. Green
ba1
Just got my C111! Awesome module! Lots of fun, as to be expected... Corsynth is becoming heavily represented in my system! I definitely need another C104 though. Somehow I currently have 10 envelopes, but only 3 oscillators. seriously, i just don't get it
Thalassa
Thanks Bill smile
levelhead3
This module pushed me over the edge - now just waiting on some additional distro boards from Tony to expand my case.
Gonna swap out a C106 for the time being to test.
Darn Noisebug and their insta-shipping! applause
