Excellent cable hanger!
sduck
experimental use of gravity
Post by sduck » Tue Jun 25, 2019 12:04 pm
Just in case any of you haven't seen this, check it out - https://www.eurodesk-z.com/products/hex ... ble-hanger
Only a limited number available currently, but if there's enough demand, he'll make more most likely.
I have one of his euro ones, and have the other one (the one linked abovea) ordered. The euro one works really well! Does what it's supposed to - holds a whole bunch of cables neatly.
Post by lisa » Tue Jun 25, 2019 12:10 pm
Xero
Post by Xero » Tue Jun 25, 2019 12:55 pm
i was just literally telling my friend last night how i needed something like this to clean up my big mess of cables on the floor.
And done.
VinceL
Post by VinceL » Tue Jun 25, 2019 2:52 pm
It looks to me like this hanger will hold 120 or so 1/4" cables. The recommendation is to use a microphone stand with it. I would be nervous about using a mic stand with this many cables.
I had attached 2 Pomona cable hangers back-to-back on a 2x4 and then drilled a hole to slide it on top of a mic stand. The Pomona cable hangers hold about 30 cables each. With the 2 Pomona's loaded with cables, the mic stand was wobbly and placed very heavy torque where the mic stand attached to the base. I used a 40 lb. barbell weight on the base to keep it from tipping over. I have 6 foot cables; so I had the mic stand at maximum height. I was very afraid of the stand just snapping off the base.
I built the cable tree pictured below (based on a design from the late Larry Hendry) using 5 Pomona cable hangers, an old lighting stand, and 2 pieces of wood cut into triangles.
I have over 150 (mostly Dotcom cables) cables on this cable tree. They represent a lot of weight. This tree is as solid as a rock
VinceL
To paraphrase Sheldon Cooper: It's MU or No U
Rex Coil 7
Re: Excellent cable hanger!
Post by Rex Coil 7 » Tue Jun 25, 2019 3:05 pm
sduck wrote:... The euro one works really well! Does what it's supposed to - holds a whole bunch of cables neatly.
Neato.
8-)
sduck
Post by sduck » Tue Jun 25, 2019 11:16 pm
VinceL wrote:It looks to me like this hanger will hold 120 or so 1/4" cables. The recommendation is to use a microphone stand with it. I would be nervous about using a mic stand with this many cables.
I understand your trepidation! I will let folks know how it works out for me.
Thalassa
Post by Thalassa » Wed Jun 26, 2019 2:40 am
VinceL wrote: Image
Those hanging cables would be the perfect chew toys for my pet rabbits :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
josaka
Post by josaka » Wed Jun 26, 2019 3:56 am
not sure whats wrong with a bunch of nails into a bit of wood painted black..:)
cheap quick and unlimited. :tu: :banana:
sduck
Post by sduck » Wed Jun 26, 2019 12:14 pm
Yea, yea, I know, just thought I'd throw out a link to help a fellow wiggler out. Yes of course there are lots of other possible options. This is just the latest one. There have been numerous patch cord management threads in the past, if you don't like this solution find one of those.
Xero
Post by Xero » Sat Jun 29, 2019 8:11 pm
Haters gonna hate. These things are sweet. Worked out nicely
josaka
Post by josaka » Sat Jun 29, 2019 11:08 pm
some strange leaps on the internet.. suggestion = hater ..
:despair:
Flareless
Post by Flareless » Sun Jun 30, 2019 5:19 am
I like these cut-out style hangers. I've got both Dotcom models mounted on a mash-up stand. A small cymbal arm mounted off the main stand allows me to mount the smaller cable holder and offers me a place to hang my longer cables...
The freaking thing is HEAVY when fully loaded!
Rich
Lower West Side Studio
What can this strange device be? When I touch it, it gives forth a sound - Neil Peart
Starspawn
Post by Starspawn » Sun Jun 30, 2019 6:24 am
m0n0mania
Post by m0n0mania » Sun Jul 14, 2019 2:52 am
Josaka, what gauge nails do you use?
josaka
Post by josaka » Sun Jul 14, 2019 9:12 am
decide what style you want and find the right things.. :)
Return to “5U Format Modules”
