Multi ( Linking ) Envelopes !!COMPLETE!!
PietroC
Post by PietroC » Fri Jul 05, 2019 9:49 pm
I've searched but tested but can't find a way to combine env3lopes in series
Example
1st Stage A Slow Decay ( DAMK2 VCA A ) EOD to
2nd Stage a Slow Attack ( DAMK2 VCA B ) EOD to
Then i don't know how to continue
I Have as
Make Noise - Contour / Maths / XXXCoast
The Harvestman - Double Andore MK2 / King Slender Kermit
Example ( Of what i would like to continue )
3rd Stage Slow Decay combined with a tremolo like rate rising Saw LFO
( Maths CH 1-4 ) CH4 EOC to Cycle
CH1 EOR to
4th stage Slow Attack ( Contour )
How / Where do i combine these envelopes ?
Is it possible or only Modules like Control Forge - DAMK1 - ZADAR - Stages Can Accomplish this???
I have Intellijel Hubs for multiplying
https://cdn.modulargrid.net/img/racks/m ... 912648.jpg
mt3
Post by mt3 » Fri Jul 05, 2019 10:52 pm
Yes, most of those modules mentioned can handle such a task.
Dopefer A-143-2 is an amazing module for this task specifically.
For the Double Andore mk II, make sure EOA/EOD OUT for both channels are in Red mode.
The issue (if any) might be the width of DAmk2's trigger outputs might not be long enough to be detected by other modules.
To see if this is the case, patch DAmk2's ch B EOD OUT into King Slender before patching King Slender's output to the 3rd stage envelope you want to trigger. Lengthen King Slender's Decay until the 3rd stage envelope is triggered.
Dave Peck
Post by Dave Peck » Sat Jul 06, 2019 6:00 pm
There's also the Encore Electronics Universal Event Generator module, which can act as an eight-stage envelope, and the sustain 'loop' portion is selectable. So for example it can have a three segment attack and a two-segment rise/fall loop while the gate is sustaining, followed by a three segment release, or it can have a simple attack and simple release but with a complex six-segment looping LFO during the gate sustain. It also has selectable log/lin shape response and can act as a simple eight step sequencer or a multi-segment LFO with anywhere from two to eight segments.
The Grump
Post by The Grump » Thu Jul 11, 2019 1:35 pm
Erogenous Tones RADAR.
Randy
Post by Randy » Sat Jul 13, 2019 11:49 am
Something a bit different:
Go to 3:00 for the interesting stuff.
PietroC
Post by PietroC » Wed Aug 21, 2019 7:52 am
Got It
It Took a While to get it through my head :bang:
Love this stuff
