Author |
Sampler pedals with MIDI control |
br>uyb |
br>Has anyone come across a sampling pedal that allows MIDI note triggering of the sample with pitch varying according to MIDI note?
My current set up allows this but is a bit awkward to tour so looking for a smaller form factor. Have checked out the Red Panda Tensor but not quite convinced it's going to do the job.
Current set up as follows:
Capture a sample (up to 1.5 secs) in an Alesis Quadraverb
Use an Arturia Keystep to trigger the sample via MIDI, with each key on the Arturia triggering the sample at a different pitch.
Happy to take the Arturia on the road but the Alesis is a bit of a pain.
Any suggestions appreciated! br> br> |
br>dkcg |
br>You might want to take the Alesis. I thought of a eurorack solution. Analogue Systems RS-290 can do exactly this. But it will end up costing maybe 10 times more than your setup with the other modules and case it would need. br> br> |
br>uyb |
br>Thanks, looks like it would do the trick but as you said it would be pretty pricey.
This is the other thing I found that might do it:
1010Music Black Box
Seems like overkill though and doesn't look particularly robust either. br> br> |
br>cloudscapes |
br>I have a 856 for zellersasn. I haven't personally used the midi capability, but I've seen people do pretty creative stuff with it!
http://mtlasm.blogspot.com/p/856-for-zellersasn-firmware-update.html
It's not the cheapest or most accessible, nor is it for people who want something more straightforward. But it's a lovely piece of kit if you're into audio mangling and take a few hours to properly learn it.! br> br> |
br>uyb |
br>Great tip!
That looks just the thing + plenty of potential for further fun.
Thanks! br> br> |
br>tremolo3 |
br>Timefactor/H9. br> br> |
br>uyb |
br>I got the 856 for Zellersasn and it is bananas! Would highly recommend it.
Thanks to cloudscapes for the tip. br> br> |
br>smetak |
br>uyb |
br> smetak wrote: | http://www.youtube.com/watch?v=Ew_UuXB0mAY |
Nice. br> br> |
br>soundinett |
br>Bastl MicroGranny br> br> |
