XONE DB4: will i automagically get synced loops?
odditymedium
Post by odditymedium » Fri Sep 20, 2019 5:14 pm
with the db4s beat matching bpm algorithms if i feed it my buchla music easel will i get automagically synced loops?
then i dont need to muck around with midi to cv converters and tap tempo and whatnot, right?
unpunk
Post by unpunk » Mon Sep 23, 2019 6:12 am
I think I just emailed you outside of Muff when I meant to reply. Yes. The algorithms are really good (not perfect). The less beat the harder it is to calculate. But this is the best DJ tool on the market for what you want so I do not think you will be disappointed with results. All the superstar DJs beat match on this. BTW NO midi unless you work ITB.
odditymedium
Post by odditymedium » Tue Sep 24, 2019 10:43 am
i guess my question is, will my loops be synced though? how do i ensure this without having to stop/start recording super precisely?
Zenn
Hired Geek
Post by Zenn » Tue Sep 24, 2019 11:04 am
odditymedium wrote:i guess my question is, will my loops be synced though? how do i ensure this without having to stop/start recording super precisely?
Not without a midi master clock.
______________
The KLF warned us about what would happen if we gave up our freedom of expression for a cheap, plastic facade. Bill and Jimmy left the music industry for our sins.
odditymedium
Post by odditymedium » Tue Sep 24, 2019 11:15 am
aha
does the db4 not have a clock inside it?
are there cv to midi cables? that i would run from the buchla?
minimalist
Post by minimalist » Tue Sep 24, 2019 12:48 pm
Are you interested in the other features of this mixer or just looking for tight loops, because if it's the latter there are some other great options? However the effects on that mixer are great and the input matrix is really versatile. I've said a few times that if A&H sold just the center of that mixer as a 4 channel FX unit, it would do really well.
If you just want tight loops, consider the Pigtronix Infinity pedal. Two loop channels with midi sync. It locks really tight and in the mode I use you can press the switch and it won't start recording until the beginning of the next bar and after you press stop, it stops recording and starts playback from the end of the currently recording bar.
odditymedium
Post by odditymedium » Tue Sep 24, 2019 12:57 pm
well i just wanna loop my buchla music easel, and not be too bothered about timing it just right
the easel is fantastic for dance music, odd rhythmic signatures, and just straight up techno. i don;t wanna muck around with midi/cv conversion, midi devices, cables, bla di bla,
so i was just looking for the simplest solution
if the db4 can do that, then i get all these amazing other features for "free", if that makes sense, plus i can just straight up DJ, or play techno all night, just with the buchla
so any way i can make the db4 do this?
or to phrase my question differently, what other gear would do this with least hassle?
