Author |
Cheap hardware amp / cab sim for direct recording |
br>R.U.Nuts |
br>Well, the title says it all. Can you reccomend any amp and cab simulator pedal for DI recording that doesn't cost more than say 200€? Or are cheap amp sims generally no good?
I'd like to have something that gives my DI guitar signal the tones I get from my AC30. I'm after clean or slightly overdriven sounds with nice dynamics. I'm not that much into high gain or fuzzy sounds. br> br> |
br>fac |
br>You should be able to get a decent amp+cab sim for 200 euro. I'm not familiar with most models, but I would look into these:
- Used Line6 POD XT or Pocket POD
- Zoom G1 Four
- Used Boss GT-1
- Some iteration of Tech21 Sansamp.. I'm not familiar with the different models
If you're recording into a DAW, there are quite a few good options in software. br> br> |
br>fac |
br>GuyaGuy |
br>There are several plug ins in that price range. Software sims make more sense to me than hardware sims because you can save a direct in take and swap out the sim or just dial in a different tone if you want. Softube and Amplitube both do a good job and have AC-30 models. I think they have demo versions too. I usually let pedals add most of the overdrive. It might be just psychological but I prefer the response from analog dirt. br> br> |
br>R.U.Nuts |
br> GuyaGuy wrote: | There are several plug ins in that price range. Software sims make more sense to me than hardware sims because you can save a direct in take and swap out the sim or just dial in a different tone if you want. Softube and Amplitube both do a good job and have AC-30 models. I think they have demo versions too. I usually let pedals add most of the overdrive. It might be just psychological but I prefer the response from analog dirt. |
Sure, you're right. But there are two things that keep me off software:
1. I won't always be using the amp sim for recording. Often times I will be using it to just make practising more pleasant. That's why I want to be independent of a computer. I'm looking for something that's portable and doesn't challenge my patience while it's booting the DAW.
2. Most of the time I record my synth and everything in one take from the main outputs of my analog mixer. So If I'd use a computer based amp sim I would have to pipe my full mix with all the instruments through the amp sim br> br> |
br>R.U.Nuts |
br> fac wrote: | You should be able to get a decent amp+cab sim for 200 euro. I'm not familiar with most models, but I would look into these:
- Zoom G1 Four
- Used Boss GT-1
If you're recording into a DAW, there are quite a few good options in software. |
Thanks for the reccomendations. Especially the Sansamp stuff looks interesting. br> br> |
br>Kent |
br>fac |
br>
Always wanted one of those. Never seen one for sale. :( br> br> |
br>dkcg |
br>No idea on price, but Strymon has a new pedal called Iridium that's an amp/cab/room sim coming out. Maybe by the holidays? br> br> |
br>phase ghost |
br>Joyo AC Tone does the Vox sound quite well. br> br> |
br>Koekepan |
br>Zoom G3n.
Or its bro; the G3Xn.
Meets your under $200 budget. Road-ready ruggedness. Lots of effects along with amp/cab simulations. Sounds way better than it has any right to at that price.
It has my unqualified endorsement, and I've used it for professional output where nobody had even a moment's complaint about sound quality. br> br> |
