Beatstep pro as a midi to cv for old midi drum trig module?
Author Beatstep pro as a midi to cv for old midi drum trig module?
vrfats
All in the title. Looking at buying an older midi drum trig module and am curious if I could send the midi out into the bsp to turn everything into gates. I know that you can use it as a midi to CV convertor with your computer. Figured I'd just ask. Thanks.
Astrolabe23
The caveat with the BSP is that the internal sequencer overrides the midi from the midi in. What this means is that the BSP will only function as a "midi to CV" converter while the sequencer is not playing. If the internal sequencer is playing, the incoming midi acts as a live transpose for seq 1 and 2.
