How to clock STG Graphic Sequencer
MUFF WIGGLER Forum Index -> STG Soundlabs
Author How to clock STG Graphic Sequencer
pulse3000
Hello
Just got my Graphic Sequencer . But i still need to understand how i can clock it to the system .
There is this clock bus cable and connection in the back , so does it mean that i need this Time Buffer module as well ?
Time Buffer module accepts DIN input, but what about MIDI than ?
Or, is it possible to clock the Graphic Sequencer without Time Buffer as well and how ?
Thanks a lot
YONI
stick a trigger into the shift input. Have you got a midi to vc converter with a clock out? That will sync it to midi. Or you could stick an osc or lfo in the shift input and do it that way.
suitandtieguy
the shift input and stage 1 input both accept triggers.
what other modules do you have in your system?
pulse3000
Ok got it
I have midi to cv from Doepfer .
And i have also other sources .
I still didn't connect the Graphic Sequencer to my system yet .
Thats why i wanted to know how.
Thanks a lot !
