ribbon cable orientation for .mix and wavefolder
MUFF WIGGLER Forum Index -> STG Soundlabs
Author ribbon cable orientation for .mix and wavefolder
nikbee
i just bought a used wavefolder and was told the red stripe goes UP. just want to make sure that this is correct..?
also, i have 2 .mix modules coming next week.. up or down?
thanks!
suitandtieguy
crap.
i'm sorry, i didn't notice this.
red stripe is _down_ on the wavefolder. if you have one whose connector does not have the key going in the right direction (it should be on the edge, not the inside) send it back and i'll replace it for the cost of shipping.
same with the .MIX. the "red stripe" or negative rail should be all the way down in the corner of the PCB.
