Quick question about PCB mounting brackets
Author Quick question about PCB mounting brackets
RichyHo
Hi
I need to mount a PCB perpendicular to the module front panel. To do this I need some little right angle brackets - one hole for fastening to the module front panel, the other for fastening the PCB mounting holes to. Basically an L-shaped small right angle bracket with 2 small holes in it. Can't seem to find anything like this at any UK supplier.
Can you help by pointing me in the right direction please?
daverj
Mouser carries Keystone brackets:
http://www.mouser.com/catalog/catalogUSD/642/1903.pdf
RichyHo
Big G
RS Stock No. 303-5330
sduck
Or a low budget method you can use is aluminum sheets with a bend in them - drill some holes and attach them to your panel with your pots, and some holes and standoffs for the pcb's.
Here's one I made from stair flashing I got at Home Depot -
Yusynth vc mixer/panner back 2 by sduck409, on Flickr
Yusynth vc mixer/panner back 1 by sduck409, on Flickr
werock
Been looking for the little L shaped brackets too for ages with no luck, so thanks for this.
neandrewthal
Great minds think alike thumbs up
rico loverde
I do the exact same thing on mine as Sducks, I get mine at home depot as well, I use my door to bend em after I drill em. A few stand offs and yr set. Id recommend gloves though, Ive sliced the hell out of myself numerous times.
