Delay pedal tap jack...
Popski
The Cake is a Pie
Post by Popski » Sun Jan 04, 2009 8:20 pm
I've got a spare boss dd-7 Digital Delay stomp box that I want to run some stuff through.. the dd-7 has a 1/4" tap input and I was thinking I might be able to clock it from my eurorack..
anybody know what kind of a signal a pedal like this responds to?
thanks
MrDys
Post by MrDys » Sun Jan 04, 2009 9:40 pm
Since those are usually connected to momentary foot switches, 5V DC.
I've clocked other things with my modular using the expression pedal input and it's usually 5V or less to trigger it. To be safe I usually run it through an attenuator.
Post by Kent » Mon Jan 05, 2009 4:08 am
Seconded. Simply use an attenuator and then, once you've found what the appropriate level is, measure that with a Voltmeter. Done.
Some inputs also respond to 'shorts' :goatse: . These can be normally open or normally closed. Try sticking the appropriate cable into the jack (TS or TRS 1/4") and then shorting the contacts with a paper clip.
Usually, this kind of information is available in the Owner's Pamphlet.
BugBrand
Knowledge of Bugs
Post by BugBrand » Mon Jan 05, 2009 6:55 am
Hmm - I'd presume to be a short-to-ground setup.
Simple method (sure there's details somewhere) uses a clock signal from your modular to close an electronic switch such as the CD4016 or CD4066
Popski
The Cake is a Pie
Post by Popski » Wed Jan 07, 2009 1:42 am
thanks guys.. I'll be trying this out on the weekend
wetterberg
Post by wetterberg » Wed Jan 07, 2009 2:14 am
fwiw, using a switch such as the Doepfer Dual VCS should work, if you short the input to the output, right? So it's just an insert cable into the pedal, split into the input/output of the a150?
http://www.doepfer.de/a150.htm
Popski
The Cake is a Pie
Post by Popski » Sat Jan 10, 2009 1:46 am
wetterberg wrote:fwiw, using a switch such as the Doepfer Dual VCS should work, if you short the input to the output, right? So it's just an insert cable into the pedal, split into the input/output of the a150?
I have an a150.. I'm trying this first..
thanks Wetterberg and Bug
haiku-ish
gigwilling with dilsexy
Post by haiku-ish » Wed Feb 04, 2009 6:40 am
do you know where i can find such a schematic ?
thanks !
