| View previous topic :: View next topic |
| Author |
RackPlanner 1.3 |
dougcl Number 6
    Posts: 4000 Location: Portland OR
Posted: Fri Feb 12, 2010 5:35 pm Post subject: |
Hi guys, the rack images and xml files are linked from this page:
http://squiggletronics.com/files/RackPlannerModules/index.php
We have more formats supported in the library than there are rack xml files and rack images.
When I want a rack image, I just take a the smallest module in the format, and get a jpg of it. Edit the jpg so that it is all black or gray, and has the original holes only. Now use MS Paint or similar to copy and paste the module out as many times as needed to create the rack width you want. I usually put a light vertical line at the rightmost edge as an indicator of the rack width. Save that, and that's your rack image  |
| Back to top |
BananaPlug Super Deluxe Wiggler
     Posts: 1894 Location: PHL USA
Posted: Fri Feb 12, 2010 5:54 pm Post subject: |
| I could have the site generate the rack images and xml files in software so that you could pick a format and pick how many rows and columns you want. I think they should be proportional to actual sizes of the different formats. Any suggestions for default scale or anything? |
| Back to top |
dougcl Number 6
Posted: Fri Feb 12, 2010 6:00 pm Post subject: |
| Probably best to use whatever scale is most likely to be submitted as modules. If the rack is too small, the module images will always be scaled down to fit, and the results so far have not been great on image reduction. |
| Back to top |
Kent Large Member
     Posts: 8003 Location: Vienna, Austria
Posted: Mon Apr 26, 2010 8:11 am Post subject: |
Hey, Doug. I'm wondering how a fellow could lay out a Euro Planner and also a Frac Planner. I'm an XML Knucklehead. How does this work? Can you walk me through it? Holding my hand and all? _________________ Kent: Putting the 'ass' in "World Class"
More Polyphony than Talent ™ |
| Back to top |
qu.one hypnotic and sanctified
   Posts: 3809 Location: Bronx, NY
Posted: Mon Apr 26, 2010 8:48 am Post subject: |
i think there already is a Frac option… and modules. _________________ www.pro-modular.com | MW OpenTape | Instagram
Josh has the proportions of a shaved Yeti, so if he sat on me I would be reduced to Quantum Foam. - Grant Richter |
| Back to top |
Kent Large Member
Posted: Mon Apr 26, 2010 9:07 am Post subject: |
I've got the Frac Modules installed where my Euro Modules are and they come out smashed up. Just a couple of millimeters wide. I've moved them to their own folder and then they all come out as 1 module wide in size and blanked out in grey. _________________ Kent: Putting the 'ass' in "World Class"
| Back to top |
Posted: Mon Apr 26, 2010 10:01 am Post subject: |
| Try looking here. There's some general explanation and links to the readme file and to folders where you can find rack images and XML files for the different formats. |
| Back to top |
Posted: Mon Apr 26, 2010 10:05 am Post subject: |
it all dependent on the rack, the HP settings etc. you would need to make sure the background is a Frack Rack. see below for some basic settings:
| Back to top |
dougcl Number 6
Posted: Mon Apr 26, 2010 10:28 am Post subject: |
You would have to modify the HP property in the XML of each frac module to estimate the frac module width in terms of euro HP.
For example, frac HP of one is something like 8 or 10 HP of euro.
You can either open each module zip, edit the module.xml, or I suppose you could go to banana plug's module maker with your frac module images, and just make them all again as euro modules (don't save them to the library!)
Doug |
| Back to top |
dougcl Number 6
Posted: Fri Nov 19, 2010 11:02 pm Post subject: |
Hi folks, I just released an update to RackPlanner. We are now on version 1.1
Image quality on scaling has been fixed.
Right click and save this over your existing RackPlanner.jar file: RackPlanner.jar |
| Back to top |
dougcl Number 6
Posted: Sun Nov 21, 2010 12:50 am Post subject: |
Here's an example of the new scaled image quality.
| Back to top |
dougcl Number 6
Posted: Sun Nov 21, 2010 7:41 pm Post subject: |
Hi folks, 1.2 is now available. SaveAs JPG now works with any directory.
If you haven't upgraded in a while, the latest version is much improved. Just copy RackPlanner.jar over your existing one. |
| Back to top |
KNYST hiding in the forest
    Posts: 2300 Location: the Taiga, Sweden
| Back to top |
dslocum darwin's nemesis
   Posts: 1339 Location: "Exit 89", NJ USA
Posted: Wed Nov 24, 2010 12:34 pm Post subject: |
I started playing with RackPlanner about a month ago so I'm a newb, but couldn't find any MU / DOTCOM rack XMLs for studio or portable cabs. Am I missing something? _________________ Doug Slocum
Synthetic Sound Labs
www.steamsynth.com
WTB: TipTop Z-DSP
"I ordered twice as many _______ as I thought I'd need, only to find out that I'm still less than half way to having enough."
"sounds like a scary and demented merry go round." - decaying.sine
"...this whole thing was started by a dream and a mouse." - Walt Disney |
| Back to top |
dougcl Number 6
Posted: Wed Nov 24, 2010 12:52 pm Post subject: |
| dslocum wrote: | | I started playing with RackPlanner about a month ago so I'm a newb, but couldn't find any MU / DOTCOM rack XMLs for studio or portable cabs. Am I missing something? |
Probably not. Some people have created background images, and some stuff is available here: http://squiggletronics.com/files/RackPlannerModules/images/
But it's hit and miss whether what you need is there. If you can't find anything, do the following
1) Create a background image jpg and put it in the images subdirectory.
2) Create a subdirectory for your modules, and put all the modules in there.
3) Open an existing rack, delete all the modules out of it and save as a new rack.
4) Use Edit->Rack Properties to point to the background image and modules directory. Specify the correct HP for the rack. HP is the number of horizontal module spaces in your rack (must match whatever you did in the image).
Post the image and rack.xml in this subforum so others can use it  |
| Back to top |
Posted: Wed Nov 24, 2010 1:22 pm Post subject: |
Your timing is real good!
I just installed RACK-O-MATIC on ModuleMaker
Let me know how that works out.
If you want me to add more rack image formats PM me and I'll ask you for some measurements etc. |
| Back to top |
dougcl Number 6
Posted: Wed Nov 24, 2010 1:27 pm Post subject: |
OMG
Looks awesome. Maybe create a separate thread for this. |
| Back to top |
Petur Wiggling with Experience
   Posts: 272 Location: Stockholm
| Back to top |
Posted: Wed Nov 24, 2010 2:15 pm Post subject: |
Yikes. Sorry about that. I didn't know it was broken.
It's fixed now! 23.47MB of euro zips could take awhile.
Euro's gotten so big. Maybe we need some other way to pick modules for downloading. |
| Back to top |
| Back to top |
