| View previous topic :: View next topic |
| Author |
RackPlanner 1.3 |
BananaPlug Super Deluxe Wiggler
     Posts: 1894 Location: PHL USA
Posted: Wed Nov 24, 2010 5:59 pm Post subject: |
Just fixed another broken thing in today's revised ModuleMaker. That's what I get for rushing it out the door. Nothing serious just a typo disabling essential functions. |
| Back to top |
Drumdrumdrumdrum What she said
 Posts: 2908 Location: Tropical Australia
Posted: Fri Jul 29, 2011 8:14 am Post subject: |
| So this is only for PC? |
| Back to top |
qu.one hypnotic and sanctified
   Posts: 3809 Location: Bronx, NY
Posted: Fri Jul 29, 2011 8:42 am Post subject: |
| Drumdrumdrumdrum wrote: | | So this is only for PC? |
not at all. it's java. _________________ www.pro-modular.com | MW OpenTape | Instagram
Josh has the proportions of a shaved Yeti, so if he sat on me I would be reduced to Quantum Foam. - Grant Richter |
| Back to top |
Henfield Better Chemistry through Sound
    Posts: 609 Location: Detroit, MI
Posted: Thu Aug 11, 2011 9:19 am Post subject: |
| Hey, I tried this today, but I could not get any Rack Image .jpgs to download for the Dotcom format. No issues with Euro, 5U, etc., but it wouldn't work for Dotcom. |
| Back to top |
dougcl Number 6
    Posts: 4000 Location: Portland OR
| Back to top |
Posted: Thu Aug 11, 2011 12:54 pm Post subject: |
Henfield: I noticed an out of date file. I replaced that, tried it, it worked.
dougcl: You're linking him to a big file of all the dotcom module zips but I think he was asking for a Rack-o-matic rack image to use in RackPlanner. |
| Back to top |
Posted: Thu Aug 11, 2011 2:32 pm Post subject: |
| BananaPlug wrote: | Henfield: I noticed an out of date file. I replaced that, tried it, it worked.
I appreciate the help! You are right, I am looking for a Rack-o-matic image. I may be doing something wrong, but it still does not work for me. |
| Back to top |
Posted: Thu Aug 11, 2011 4:20 pm Post subject: |
| Turns out I was too stingy about handing out memory and the small test I did had enough but yours did not. It will now make a 50 space wide Dotcom without complaining and should avoid fatal errors if you ask for something too big but the numbers are not working out quite as I expected so I can't guarantee that. |
| Back to top |
Posted: Thu Aug 11, 2011 8:51 pm Post subject: |
| BananaPlug wrote: | | Turns out I was too stingy about handing out memory and the small test I did had enough but yours did not. It will now make a 50 space wide Dotcom without complaining and should avoid fatal errors if you ask for something too big but the numbers are not working out quite as I expected so I can't guarantee that. |
A huge thank you!!! It works!!! I just need the Oakley MU modules added to the Library!! |
| Back to top |
essex sound lab wiggler of the spheres
    Posts: 2568 Location: Lenox, Mass
Posted: Thu Aug 11, 2011 11:56 pm Post subject: |
| Henfield wrote: | | I just need the Oakley MU modules added to the Library!! |
I've done a few, but perhaps I didn't make them public or they were rejected.
They're hard to do well because there aren't many straight-on shots of them. |
| Back to top |
Posted: Tue Jan 17, 2012 11:19 am Post subject: |
Has anyone got this working on an iPad? _________________ "Modular synths can take your ego out of the equation – which, in music, is a blessing" - Jeremy Greenspan
Gear For Sale/Trade: http://www.muffwiggler.com/forum/viewtopic.php?t=83341 |
| Back to top |
krisp14u Oakley4All!
     Posts: 965 Location: UK
Posted: Tue Jan 17, 2012 11:28 am Post subject: |
I Photographed and uploaded the whole lot this weekend just waiting for them to be processed
If anyone want the files PM or email me and I will send them over _________________ Cheers
Paul
www.krisp1.com |
| Back to top |
dougcl Number 6
Posted: Tue Jan 17, 2012 2:22 pm Post subject: |
| Drumdrumdrumdrum wrote: | | Has anyone got this working on an iPad? |
Unfortunately Apple has decided to try to kill both Java and Flash. RackPlanner is written Java, and the Modular Planner is written in Flash. Neither can be legally run on the iPhone or iPad. |
| Back to top |
Posted: Tue Jan 17, 2012 4:30 pm Post subject: |
| krisp14u wrote: | | Henfield wrote: | | I just need the Oakley MU modules added to the Library!! |
If anyone want the files PM or email me and I will send them over |
Done. Sorry for the delay.
I do intend to farm this out to module moderators but I have to write some code for that and several things have higher priorities. |
| Back to top |
Posted: Wed Jan 18, 2012 2:40 am Post subject: |
| BananaPlug wrote: |
Thank you very much for doing it so fast
you sir are a gentleman  _________________ Cheers
Paul
www.krisp1.com |
| Back to top |
akrylik Veteran Wiggler
 Posts: 612 Location: Hong Kong and Tokyo
Posted: Fri Mar 09, 2012 9:29 pm Post subject: |
If you want to make any size eurorack (not just a multiple of 84HP wide), then you can take the following rack image file:
and use it with the below rack.xml. The <cols> tag is given in HP.
| Code: | <?xml version="1.0" encoding="ISO-8859-1"?>
<rack>
<properties>
<scale>1.0</scale>
<rows>4</rows>
<cols>104</cols>
<imagesPath>./images</imagesPath>
<modulesPath>./euro_modules</modulesPath>
<rackImageFilename>euro_1HP.jpg</rackImageFilename>
<rackHP>1</rackHP>
</properties>
<modules>
</modules>
</rack> |
The above rack.xml is for the 12U 104HP gorillabox. |
| Back to top |
sgnhh Super Deluxe Wiggler
     Posts: 1525 Location: se mi
Posted: Mon Mar 12, 2012 5:41 pm Post subject: |
i got some zips from the module maker database and they all appear with gray faceplates and of the exact same width when i import them into the rack planner. any ideas what i can do to fix this? _________________ webs: http://smkstcks.tumblr.com/
soundclod: http://soundcloud.com/smokestacks |
| Back to top |
Posted: Mon Mar 12, 2012 6:44 pm Post subject: |
Maybe you didn't put those zips where RackPlanner expects to find them. There's some talk about this in the readme. The XML file defining the rack has a line saying where the modules are.
Here's an excerpt from one of my rack files:
<properties>
<scale>1.0</scale>
<rows>3</rows>
<cols>3</cols>
<modulesPath>./modcanA</modulesPath>
<rackImageFilename>modcana_rack_126_551.jpg</rackImageFilename>
<rackHP>7</rackHP>
</properties>
In the same folder as my RackPlanner.jar is a folder named modcanA and that's where the zip files are. Other formats are in other folders next to that one, such as Euro, Frac, etc. |
| Back to top |
| Back to top |
Posted: Fri May 11, 2012 11:17 pm Post subject: |
I just downloaded this and got it working on an iMac
Looks great.
Where do I find all the images? There are a few folders of images, but not a whole lot.
When clicked on one of xml files my East West VST opened???! _________________ "Modular synths can take your ego out of the equation – which, in music, is a blessing" - Jeremy Greenspan
| Back to top |
