Filtrex 2 build help
Author Filtrex 2 build help
joechip
Hi All,
Been lurking on here for sometime and bought some Oakley boards a while back and I am now in the process of building a stereo Filtrex 2.
Checked all caps/diodes/ICs orientation ok, did have c10 wrong way, fixed and on initial power up had a short which was causing u15 to run hot, repaired and all ok now. Bal/trim pots 500k/10k respectively.
Completed first board build and tested on its own connected to input source, unit powers up ok (using 15AC adapter to pins ac1/ac2). Input signal lights trig/peak LED, LFO rate LED lights and rate can be adjusted. However, no apparent filtering going on, freq/res/fizz/smooth pots have no effect. Dry/wet knob fully clockwise no sound, anti-clockwise passes dry signal through unit fine. gain pot adjustment fine too.
I have spares for 2nd board so changed u2/u3/u4 no change.
A pretty basic building knowledge, built some MFOS stuff, x0xbox and monome. No scope here, only a meter for testing.
Any help for things to start checking would be most appreciated, as no schematics here.
Joe
Synthbuilder
Dead filter probably. And the most probable cause is a dead resonance pot.
But make yourself an audio probe and see if you can spot where the signal is being lost. For a quick lash up audio probe see article here:
http://www.diystompboxes.com/pedals/debug.html
If you need Filtrex schematics e-mail me.
Tony
joechip
Thanks for the reply Tony, I did something similar for the x0xb0x, will give it a check and get back if I need schematics.
Thanks again,
Joe
joechip
loosing the signal after r33
just in case it helps, all filter/res/fizz/smooth/lfo rate adjustments etc can all be heard so they are all ok.
The filter sounds amazing by the way, if I can only get the signal to the wet/dry pot I'm in heaven.
Any help/schematic much appreciated.
Joe
Synthbuilder
E-mail me.
Tony
joechip
Schematic request email sent.
Thanks,
Joe
joechip
Tony,
Got the schematics and the problem was r40, knew something around r38-40 was up but just couldn't quite work it out without the schematic.
Now the fun really begins, getting the 2 boards to run in stereo. Got myself a 3U rack and planning on mounting all the jacks and extra switches on the front panel.
Just to add, now I can hear it through the main out the Filtrex 2 sounds really, really nice. great job on the design. Mellower than my Sherman but in a good way, which is exactly what I was hoping for.
Many Thanks,
Joe
