cats and modular synths, but mostly cats
Tested Audio interfaces that pass DC voltages.
Goto page 1, 2, 3, 4, 5, 6, 7, 8, 9  Next [all]
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Volta
Author Tested Audio interfaces that pass DC voltages.
Last Visit: 19 Jun 2013
PostPosted: Thu Jan 22, 2009 3:34 pm    Post subject: Tested Audio interfaces that pass DC voltages. Reply with quote Add User to Ignore List
Hello all. Why don't we do it ourselves and develop a list of audio interfaces that can pass DC voltages?
We need to agree upon what this means. For now, let's all use the same audio files for the sake of consistency. If the interface passes these files, then proceed with the "one minute test". All 'qualified' interfaces in this thread should hold a minimum of +5VDC & -5VDC for one minute. Feel free to comment upon this within this thread.
+/- 10VDC would be fantastic, but highly unlikely.
I need to rely upon one of you guys to generate the 'one minute' test files. Shoot 'em over to me and I'll attach them to this post.
Here's my list of tested interfaces. Thus far, I've only tested the outputs. I just want to get the list started & will append to it at a later date. Here goes:
Mackie Designs
Onyx 1200F : FAIL
Onyx 400F : FAIL
Onyx Satellite: FAIL
U-420 & U-420d: FAIL
d4Pro DJ Mixer: FAIL
ProFX Mixer: FAIL
TAPCO
Link•Firewire: FAIL
Link•USB: FAIL
Noting the inputs will be of value in a rig. I'll get to those later.
Files
DC Wave File from RME's site
http://www.imjohn.com/misc/ForKent/ForKent2_.05HzSquare.wav
http://www.imjohn.com/misc/ForKent/ForKent2_.5HzTo.001HzSquare.wav
3vcos
Must have slack/modules
PostPosted: Thu Jan 22, 2009 3:50 pm    Post subject: Reply with quote Add User to Ignore List
so are there any devices that have been confirmed to pass DC voltages? (compatable with Volta)...
rlainhart
R.I.P.
Last Visit: 20 Dec 2011
PostPosted: Thu Jan 22, 2009 5:48 pm    Post subject: Reply with quote Add User to Ignore List
So far, the only ones I've heard of as specifically compatible are "MOTU interfaces with 1/4" outputs". That would include the 828, 828mkII, 828mk3, Ultralite, UltralitemkII, Ultralitemk3, Traveler, Travelermk3 (was there a TravelermkII?), 896HD, 896mk3.
Richard Lainhart
http://www.otownmedia.com
http://www.downloadplatform.com/richard_lainhart
http://www.vimeo.com/rlainhart
http://www.youtube.com/rlainhart
http://richardlainhart.bandcamp.com/
http://soundcloud.com/rlainhart
rlainhart
R.I.P.
PostPosted: Thu Jan 22, 2009 5:59 pm    Post subject: Reply with quote Add User to Ignore List
Note that list includes some older discontinued units, some of which should be easy to find cheap on eBay or other sources.
Richard Lainhart
panda30y
PostPosted: Thu Jan 22, 2009 10:28 pm    Post subject: Reply with quote Add User to Ignore List
According to stretta's twitter account, the RME Fireface does not have DC coupled output despite what their website says. So add that to a list of interfaces that don't cut it.
I'm sure most people have seen it, but he does have a wonderful blog which shows he works (at least in some capacity) for MOTU. http://stretta.blogspot.com/
View user's profile Send private message AIM Address
criticalmonkey
Last Visit: 13 Jun 2013
PostPosted: Fri Jan 23, 2009 1:24 am    Post subject: Reply with quote Add User to Ignore List
I can confirm these will pass dc: motu orig 896 and motu 2408 mk2
though not sure about volta compatibility
motu 2408mk1 will not
PostPosted: Fri Jan 23, 2009 5:04 am    Post subject: Reply with quote Add User to Ignore List
Apparently, Volta is simply an Audio Unit (AU) plug-in for now. As long as your interface is Core Audio compliant is should be Volta compatible.
I can't find a clear picture of the MK1 back panel. However, it does appear that the Analog Outs are on RCA jacks. This is keeping in line with the statement about Volta working on all MOTU interfaces that have 1/4" outputs. Good to know.
astroschnautzer
PostPosted: Fri Jan 23, 2009 5:53 am    Post subject: Reply with quote Add User to Ignore List
I would be interested if somebody finds an adat ad/da that has dc coupled outputs. Or if somebody finds a way to mod an adat ad/da interface for dc coupling.
doctorvague
ole fuckity fuck
PostPosted: Fri Jan 23, 2009 7:39 am    Post subject: Reply with quote Add User to Ignore List
Thanks for the info and testing!
I own a 2408 Mk1 and have already tested this in the past in a little different manner. It has RCA outs that are rated -10db (consumer), not +4db line outs - a distinction worth mentioning here. I was only able to get just under 2 volts out of it. I am using short (5ms) wav files that are a straight line, not a sine wave, etc, to generate triggers. I tried files at various levels to test where it maxes out. The triggers do work and can be brought up to higher level with any CV module that has some gain.
Here's a thread on EM detailing my previous exploits creating trigger pulses, which is probably a bit superfluous here:
http://electro-music.com/forum/viewtopic.php?t=28737
The way I was approaching triggers, multiple trigger channels can be OR'd together then amplified with one buffer amp. But with multiple outputs/CV's being used you'd have to have a buffer amp for each channel = not very practical.
Won't have time to do any more testing until next week, but the 2408 fails the 5V test anyway.
FWIW, my Ramsa DA7 console +4 outputs generated about 9V max using the above method (short triggers, not continuous CV).
Phil
sydilaxe
Last Visit: 06 Jun 2013
PostPosted: Fri Jan 23, 2009 11:53 am    Post subject: Reply with quote Add User to Ignore List
I tested the following:
Metric Halo interfaces (ULN/2 2882): Does not pass DC.
It also looks like my Behringer ADA-8000 does not pass DC either (and I had high hopes for that one!).
Anyway...looks more and more like a MOTU interface is the way to do. I bet they will actually sell more of their interfaces that users will only want to dedicate to Volta.
PostPosted: Fri Jan 23, 2009 12:59 pm    Post subject: Reply with quote Add User to Ignore List
Great post & link, Doctor Vague. Thanks for that.
Sydilaxe, MOTU is competing against their own legacy products. If people want an interface that can pass CV (and that is all that they care about) then they will definitely go low-ball on the price.
Dragonslair
Last Visit: 01 Jun 2013
PostPosted: Fri Jan 23, 2009 1:59 pm    Post subject: Reply with quote Add User to Ignore List
M-Audio Delta 44/66 - FAIL
PostPosted: Fri Jan 23, 2009 2:09 pm    Post subject: Reply with quote Add User to Ignore List
Dankeschön!
Dragonslair
PostPosted: Fri Jan 23, 2009 6:49 pm    Post subject: Reply with quote Add User to Ignore List
Your welcome,
I would also assume none of the other M-Audio interfaces would work, since they are based around the same basic hardware designs.
lukas412
PostPosted: Wed Jan 28, 2009 11:09 am    Post subject: Reply with quote Add User to Ignore List
Headphone output on an original RME Multiface will work, main outputs will not. I have heard that the new version with the volume control for the headphones will not work.
Luke
astroschnautzer
PostPosted: Wed Jan 28, 2009 11:18 am    Post subject: Reply with quote Add User to Ignore List
Luke
I guess the ff400 would too but ff800 not
binray
Last Visit: 08 May 2011
PostPosted: Sat Jan 31, 2009 4:44 pm    Post subject: Reply with quote Add User to Ignore List
The phones out from FF 400 , Digiface, Multiface (not II) and HDSP9632 are all DC-coupled, without capacitor at the output jack. So you can easily try it with your MF.
Units with pot (MF II and FF 800) do have one capacitor before the pot.
Regards
Matthias Carstens
RME
felix
Loves the manuals!
Last Visit: 08 May 2013
PostPosted: Sat Jan 31, 2009 4:58 pm    Post subject: Reply with quote Add User to Ignore List
Apparently the various E-MU interfaces do not filter DC on the outputs. I don't have one to actually verify that though.
http://felixinferious.blogspot.com
http://felixinferious.bandcamp.com
View user's profile Send private message Send e-mail AIM Address
jovius
Last Visit: 29 Nov 2011
PostPosted: Sun Feb 01, 2009 10:24 am    Post subject: m audio delta 1010 Reply with quote Add User to Ignore List
thought i mite have a chance with this m audio delta 1010, it's 1/4 tsr but fail :-(.......
slight change of path but I've got a emu 6400 in a rack in a basement might dig it out just to see if i get anything out of it, could be some interesting modulation possibility if it works
Chuck E. Jesus
holier than thou
Last Visit: 30 Mar 2012
PostPosted: Sun Feb 01, 2009 2:00 pm    Post subject: Reply with quote Add User to Ignore List
i'll have to try it out on mine...
Post new topic   Reply to topic    Muff's Modules & More Forum Index -> Volta All times are GMT - 5 Hours
Page 1 of 9
